Problem with driver to IDT high definition audio CODEC
blueberry
10:54 PM
Any suggestions would be appreciated. My audio no longer works. This message appears when troubleshooting:
There is a problem with the driver to IDT high definition audio CODEC. Reinstalling the driver might fix the problem.
The automatic "apply this fix" does not work.
What should I do?
Thanks.
windows 7 Home premium 64 bitIntel Core i5 ACPI x64-based pc6.00 GB
HP Pavilion dv6 Notebook PC
6.00 GB
ATI High Def., Bluetooth, IDT high def. CODEC, HP webcam spl
Generic PnP monitor
Samsung HM640JJ
Fill in your system specs. Without it, we have no idea what hardware you own.
Windows 7 Ultimate x64 SP1Core i7-2670QM8GB DDR3 PC3-10600Intel HD Graphics 3000 + GeForce GT 540M
Dell XPS 15 L502x
Core i7-2670QM
8GB DDR3 PC3-10600
1TB 5400RPM Seagate
Thanks for your patience. I added what I could find to my system specs. Is that the correct information to be helpful?
6.00 GB
Generic PnP monitor
Samsung HM640JJ
Yes, that's helpful. Have you visited HP and looked for the correct audio driver for your laptop?
Dell XPS 15 L502x
Core i7-2670QM
8GB DDR3 PC3-10600
1TB 5400RPM Seagate
Sorry, but I don't know what you mean my this question. :o I have searched HP but do not know what to look for. An audio driver does not seem to be listed with the specs.
6.00 GB
Generic PnP monitor
Samsung HM640JJ
