Hello. I have a new, custom build and cannot get the front audio to work. The two USB ports along side the Mic and Headphone jacks work fine.
System Specs
The motherboard is a GA-990XA-UD3. Chipset AMD RD9XO Rev 02. Southbridge AMD
SB10/950 R40. Bios Award Software Ver F8
CPU: AMD Phenom II x6 1090T Black Edition Tuban HDT90ZFBGRBOX
Memory: Corsair Vengeance 16GB 4 x 4GB CMZ16GX3M4A1600C9
OS: Windows 7 (6.1) Home Premium SP 1 (Build 7601) 64 bit. Direct X 11.0
Don't think it makes a difference but I am running displayport out of the graphics card (Zotac 560 ZT-50701-10M) into the monitor (NEC PA241)
I downloaded updated
drivers for the Reatec HD Audio Manager but that made no difference.
Audio out from the back panel works fine.
Any advice on what to try next would be greatly appreciated!
