| Windows 7: Headphone volume too low !! |
23 Jul 2012
#1 | | |
Headphone volume too low !! Hai guys,
My headphone volume is too low even at max volume settings.. using windows 7 64bit ultimate.
Headphone : HS 320 (Creative).. tried with other 1-2 headphones.. all of them .. volume is too low !!
Realtek sound driver : 6.6.1.6662
Intel : DH55TC
No problems with speaker volumes.. its loud and clear (5.1 creative t6160)
Any help would be much appreciated.. !! | My System Specs |
| OS Windows 7 Ultimate x64 |
23 Jul 2012
#2 | | Windows 7, 64 bit Home SP1, Win 8 Pro 64 bit Citrus Co, FL |
Has the headphone port on the front panel ever worked correctly? If not, it may be a defective front panel assembly (and/or cable) on the case. Although it shouldn't make a difference, use the HD Audio connector from the front panel to the motherboard audio connection. Many cases also have an AC97 audio connector, which is the older standard. If you have this you can try it, to see if the HD audio connector/cable is the problem. | My System Specs | | Computer type PC/Desktop System Manufacturer/Model Number My Own Build OS Windows 7, 64 bit Home SP1, Win 8 Pro 64 bit CPU Intel i7 3770 Motherboard Gigabyte GA-Z77X-UD5H Memory 16GB GSkill Ripsaw F3-14900CL9Q-16GBXL Graphics Card Sapphire HD7770 Sound Card RealTek Monitor(s) Displays Viewsonic VA2448 Series 24" LED Screen Resolution 1920X1080 Keyboard Kensington wired Mouse Logitech Wireless PSU Antec High Current Gamer HCG-620M Modular Case Coolermaster HAF XM Cooling Corsair H80 Liquid cooling with aftermarket Nexus quiet fans Hard Drives 240GB Intel 520 SSD for Win 7
128GB OCZ Vertex 4 SSD for Win 8
1 TB Seagate drive for backup Internet Speed 40 MB/sec (Cable) Antivirus Microsoft Security Essentials and Malwarebytes Browser I.E9/Firefox Other Info Sonar X2 Professional 64 bit Recording Software with Roland Octa-Capture and MAudio Fast Track Ultra 8R recording interfaces, Frontier Tranzport wireless control unit, Behringer BCF2000 Control Surface.
Five USB connected optical drives for CD Audio production using Nero 11
Other systems: Desktop with i5 3550 CPU, LenovoZ560 Laptop with Win 7 64 bit HP, SP1, new iPad |
23 Jul 2012
#3 | | |
Thanks for the reply mate.. !!
Its not working even i connect headphone from the back.. again volume too low !!
Will try that and reply !! | My System Specs | | OS Windows 7 Ultimate x64 |
23 Jul 2012
#4 | | Windows 7, 64 bit Home SP1, Win 8 Pro 64 bit Citrus Co, FL |
If the speakers have proper volume but the Headphones do not plugged into the GREEN speaker jack on the rear it says there is a problem with the headset. That headset has a volume control on it, have you tried that? | My System Specs | | Computer type PC/Desktop System Manufacturer/Model Number My Own Build OS Windows 7, 64 bit Home SP1, Win 8 Pro 64 bit CPU Intel i7 3770 Motherboard Gigabyte GA-Z77X-UD5H Memory 16GB GSkill Ripsaw F3-14900CL9Q-16GBXL Graphics Card Sapphire HD7770 Sound Card RealTek Monitor(s) Displays Viewsonic VA2448 Series 24" LED Screen Resolution 1920X1080 Keyboard Kensington wired Mouse Logitech Wireless PSU Antec High Current Gamer HCG-620M Modular Case Coolermaster HAF XM Cooling Corsair H80 Liquid cooling with aftermarket Nexus quiet fans Hard Drives 240GB Intel 520 SSD for Win 7
23 Jul 2012
#5 | | |
Try opening up the Volume Mixer when the headphones are plugged in and make sure all the volume levels are turned up. You can open the mixer by clicking on the 'Speaker' in the notification corner and clicking 'Mixer'
If that doesn't work... By any chance are you using skype or a voice communication program when your headset is plugged in? | My System Specs | | Computer type PC/Desktop System Manufacturer/Model Number Custom Build OS Windows 7 Ultimate x64 CPU Intel i7-3770K Ivy Bridge 3.5GHz (3.9GHz Turbo) LGA 1155 77W Motherboard Gigabyte Z77-D3H (rev. 1.0) Memory CORSAIR Vengeance 16GB (4x4GB) 240-Pin DDR3 1600 (PC3 12800) Graphics Card Radeon HD 6970 2GB 256-bit GDDR5 Sound Card Integrated Audio VIA VT2021 codec Monitor(s) Displays Dual (19'' Samsung 1440 x 900 (2ms) SyncMaster Widescreen) Screen Resolution Dual (1440x900) Keyboard Razer Deathstalker Mouse Razer DeathAdder PSU CORSAIR HX850 - 80 PLUS GOLD Certified Case COOLER MASTER HAF 922 Cooling COOLER MASTER Hyper 212 Plus Hard Drives Windows: Crucial M4 CT128M4SSD2CCA - 128 GB, SATA III MLC Internal Solid State Drive (SSD)
WD Caviar Blue - 500 GB, SATA 3.0 Gb/s, 16 MB Cache, 7200 RPM (WD5000AAKS)
WD Caviar Black - 1 TB, SATA 6.0 Gb/s, 64MB Cache, 7200 RPM (WD1002FAEX) Antivirus Microsoft Security Essentials Browser Google Chrome Other Info Microsoft LifeCam Cinema, A40 Audio System - MLG Edition, M-Audio Bx8 D2's |
23 Jul 2012
#6 | | |
Quote: Originally Posted by fireberd If the speakers have proper volume but the Headphones do not plugged into the GREEN speaker jack on the rear it says there is a problem with the headset. That headset has a volume control on it, have you tried that? Tried everything !! speakers has full volume. !! no problems with that
Interestingly, when i connect it through another speaker's jack (logitech) headphones has max volume !! loud & clear !!
but when i connect directly through computer,volume is low at max possible settings | My System Specs | | OS Windows 7 Ultimate x64 |
23 Jul 2012
#7 | | |
Quote: Originally Posted by Deception Try opening up the Volume Mixer when the headphones are plugged in and make sure all the volume levels are turned up. You can open the mixer by clicking on the 'Speaker' in the notification corner and clicking 'Mixer' Everything is at max !!
Quote: Originally Posted by Deception If that doesn't work... By any chance are you using skype or a voice communication program when your headset is plugged in? No.. !! | My System Specs | | OS Windows 7 Ultimate x64 |
23 Jul 2012
#8 | | |
Is their any driver updates iam missing here ??
realtek driver is upto date though! | My System Specs | | OS Windows 7 Ultimate x64 |
23 Jul 2012
#9 | | |
Can you try a different pair of headphones/multiple devices and see if they have issues? Cause if it is only the one pair of headphones... That would mean they are the problem (or at least they have compatibility issues with your machine) | My System Specs | | Computer type PC/Desktop System Manufacturer/Model Number Custom Build OS Windows 7 Ultimate x64 CPU Intel i7-3770K Ivy Bridge 3.5GHz (3.9GHz Turbo) LGA 1155 77W Motherboard Gigabyte Z77-D3H (rev. 1.0) Memory CORSAIR Vengeance 16GB (4x4GB) 240-Pin DDR3 1600 (PC3 12800) Graphics Card Radeon HD 6970 2GB 256-bit GDDR5 Sound Card Integrated Audio VIA VT2021 codec Monitor(s) Displays Dual (19'' Samsung 1440 x 900 (2ms) SyncMaster Widescreen) Screen Resolution Dual (1440x900) Keyboard Razer Deathstalker Mouse Razer DeathAdder PSU CORSAIR HX850 - 80 PLUS GOLD Certified Case COOLER MASTER HAF 922 Cooling COOLER MASTER Hyper 212 Plus Hard Drives Windows: Crucial M4 CT128M4SSD2CCA - 128 GB, SATA III MLC Internal Solid State Drive (SSD)
23 Jul 2012
#10 | | |
@ Deception,
No its not abt headphone.. i've tried with other ones too.. ! | My System Specs | | OS Windows 7 Ultimate x64 Headphone volume too low !! problems? All times are GMT -5. The time now is 04:52 AM. | |
