Windows 7: xonar d2x sound card loud buzzing noise problem
26 Jul 2012   #21
neo101
WIN7 Ultimate 64bit
Well I never installed Silverlight and have never come across a site demanding I install it or have any problems with any websites I visit or installed software
I ain't been brainwashed into installing it - like some!
So there is no point.
Laptop freezes for 1 minute & makes a loud buzzing noise in my room
I have a Toshiba Satellite laptop, about 4 years old. I've had this problem for a while now. Whenever I take my laptop inside my bedroom, unplugged or plugged in, doesn't matter, when I try to watch a YouTube video, 10-30 seconds in my laptop freezes and makes a loud buzzing noise from either...
Performance & Maintenance
Artifacts in post and monitor freezing with loud buzzing sound
Hello there,i really need you help ! So i bought a new graphics card,the Radeon R9 290 and i have the following problems 1)When i post up the pc instead of the BIOS image i am getting those random artifacts http://i57.tinypic.com/vhrm0n.jpg 2) In random times my monitor freezes with...
Graphic Cards
Loud buzzing noise before bsod
system fine all day was playing poker on 2 screens - put the footie match on after 5 mins everything froze heard a buzzing noise from speakers then bsod code 124(hardware) 3 weelks on off - i have checked everything
BSOD Help and Support
Audiophile 2.1 sound system for Xonar D2X sound card.
I have given up on getting a good 5.1 or 7.1 sound system for my pc since it requires a receiver and all. What I am looking for right now is a 2.1 sound system that can be directly plugged in to my Asus Xonar D2X sound card. The system should have a really decent subwoofer with tight and deep...
Complete freezes and loud buzzing noise ? no idea how to fix
Hi, I feel like a regular on here with the amount that goes wrong with my pc, but anyway. I've been getting random computer crashes where everything freezes and the audio speakers emit a very loud buzzing noise and the only way i can carry on is if i hit the restart button.. Now originally i...
mouse problem with loud noise
Hi I hope you can help me. Got a new computer a couple of months ago with HID-compliant mouse supplied (optical - sensor plugs in the back). Loaded in Windows 7 and for a couple of months everything was fine. Then yesterday, I was listening/watching a video when a continuous loud pitch...
Hardware & Devices
