No front Panel audio detected but Rear Audio works on Asus P8H 61-M LX
blueyedsamurai
12:53 PM
My front USB slots work and every connector on the rear works fine yet when
i plug headphones into the front audio jack and nothing is detected.
My Bios are updated to the latest version, i have also tried switching to AC97 but makes no difference. Swapping between HDMI and s/pdif doesn't also does nothing.
The case is a fairly cheap case being a SHAW GT-M2 although it is new.
I have a dual boot of Windows 7 and OSX Lion the front doesn't work with either.
All drivers are up to date with no yellow ! in device manager
Windows 7 Ultimate x64Intel i7 4790k16GB DDR3Nvidia Geforce GTX 970
Intel i7 4790k
MSI Z87-G45
16GB DDR3
LG 24 inch
Corsair Obsidian 450D
Check to make sure that the front panel audio cable is actually plugged into the audio header on the motherboard. If the motherboard has HD audio and the front panel has a plug marked HD-Audio, then plug that into the motherboard. Make sure that it is correctly lined up, otherwise the front panel won't work correctly.
Dwarf Dwf/11/2012 r09/2013
Windows 8.1 Pro RTM x64
ASRock Z77 Extreme4-M
Iomega 1.5TB Ext USB 2.0
WD 2.0TB Ext USB 3.0
Gigabyte IF233
Avast! 8.0.1497
IE 11
yeh it is, have disconnected and reconnected several times, double checked with the manual as well
Intel i7 4790k
MSI Z87-G45
16GB DDR3
LG 24 inch
I would suspect a front panel problem. I built a new system a couple of years ago and had that problem with the front panel USB. I contacted the case vendor and they sent me a new front panel assembly which fixed the problem.
But open the front (most just pull away from the case) and check the connections at the front panel assembly.
My Own Build
Intel i7 6700K
ASUS ROG Maximus VIII Hero
16GB Corsair Dominator
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
2 TB drive for backup
EVGA Supernova 750G2
BeQuiet Silent Base 600
Deepcool Captain 120EX
Microsoft Wireless 2000
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
Im thinking it is that, the usb connector closest to the audio is a bit dodgy as well it has errors when im trying to transfer stuff yet the other one seems fine. Its a budget case so im suspecting the build quality isnt the greatest
Intel i7 4790k
MSI Z87-G45
16GB DDR3
LG 24 inch
Case price, although something to consider, isn't the only criteria. The case that I had problems with was a $100 case.
My Own Build
Intel i7 6700K
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
Ive built a few computers with these cheap cases they are only $40.00 with a PSU and haven't had any problems.
Although with a bit of searching a few people said they did with power buttons not working and when they swapped it into a new case it worked.
The left front USB gives me errors while transferring as well so i guess its not just the front Mic and Audio
I guess ill go and swap it for a new one or a different case and at least that will let me know if its the case or the MB
Intel i7 4790k
MSI Z87-G45
16GB DDR3
LG 24 inch
purchased a cheap coolermaster which had a front HD Audio connector instead of just the ac97 and it worked :)
Not sure if the connector was faulty or the MB didnt support AC97 properly even though it has a selection in the bios.
Intel i7 4790k
MSI Z87-G45
16GB DDR3
LG 24 inch
Great. Must have been a bad front panel in the other case.
Be careful with the inexpensive power supplies. They tend to be overrated (watts) and have poor voltage regulation. We've seen reports of motherboard damage due to the "cheapie" power supplies when I worked the Dell forums.
My Own Build
Intel i7 6700K
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
I also has same problem but now figured it out, just click start and open HD Vdeck( sound driverfolder) and click small setting icon in right bottom side ,now click AC 97 front audio. thats all .It works for my Asus M5A78L-M/Usb3 board.
windows 7 ultimateAMD ATHLON x4 6304GB KINGSTON HYPER X BLU 1600 MhzXFX HD 4670 1 GB DDR3
ASSEMBLED
windows 7 ultimate
AMD ATHLON x4 630
Asus M5A78L-M/USB 3
ONBOARD
SAMSUNG B2230 22"
KINGSTON SV 300 120 GB SSD
320 GB SAMSUNG 7200 RPM
ANTEC VP450P
COOLERMASTER TX3
MICROSOFT
4 MBPS
