Windows 7: VIA HD Audio Deck - Front panel headphone device not producing sound
05 Aug 2012   #11
np726
Windows 7 Pro x64
Under the "Independent Headphone" setting, with headphones set as the default device, this is what is shown in the playback devices window:
VIA HD Audio Deck - Front panel headphone device not producing sound-playbackdevices3.jpg
Notice that the device is receiving sound. However, there is no sound coming from the headphones.
Quote   Quote: Originally Posted by bassfisher6522 View Post
That way when the head phones are plugged in, they will be your default listening device and you should have sound and when unplugged your speakers will take over.
The point of what I am trying to accomplish is to have the headset always plugged in, and be able to switch between my stereo and my headset without having to unplug the headset, and instead simply changing which device is the "default" device.
06 Aug 2012   #12
bassfisher6522
Windows 7 Ultimate 64 bit
check your headphones....is there a switch on them to mute sound...I have the Razer Carcharias headset. Like most high end headsets there is an independent volume control with a mute switch. Make sure that it's not in the off position.
06 Aug 2012   #13
bassfisher6522
Here is what I'm talking about....
VIA HD Audio Deck - Front panel headphone device not producing sound-headset.png
06 Aug 2012   #14
bassfisher6522
BTW...what brand is your headset that you are using?
06 Aug 2012   #15
np726
Windows 7 Pro x64
The headset isn't muted. It's a Steelseries Siberia V2. Volume knob is turned up on the independent volume control, tested by connecting to another device.
06 Aug 2012   #16
bassfisher6522
Well...I'm out of ideas...I'm betting that it's a setting issue...I just can't pin point it. Maybe someone else might have an idea...one we've over looked...something.
25 Aug 2012   #17
BaronV
Win 7 64bit home preium
Id like to bump this thread because im having an IDENTICAL problem to the OP.
My motherboard is similar of the same generation (Gigabyte Z77-D3H) and im using Windows 7 64 bit home premium. My audio header is identical to the OPs, and my front panel audio is connected to my motherboard using the HD audio connector.
If i select redirected headphones in the via deck it works fine and even mutes the speakers if that option is selected (this proves that the font panel HD audio is working)
However when i select independent headphones, windows shows sounds being played from it (using the playback devices screen) but no sound is coming from the headphones.
Im using the latest drivers from VIA.
Is there no solution to this??
25 Aug 2012   #18
BaronV
I still think "you can't get there from here" on what you want to do. When you select the headphones as default playback device there is no sound module to generate the audio thus you don't get any sound. You are going to have to leave the Speakers (actually your VIA sound device) set as default playback device and then manually set set the sound routing in the Via control panel when you want to do what you want.
This is completely untrue (or rather if it is true then its going against the HD Audio specs)
Front panel audio has its own header which is why you can have independent or redirected output and even swap the front plugs if you want to.
25 Aug 2012   #19
BaronV
I found this on the VIA forums. Problems configuring Via VT2021 - VIA Forums
In short, the latest 3 versions of the drivers for the VT2021 audio header is bugged. The only solution is to install an older driver (newest with working indept headphones is ver 10100).
The newest version of the driver on the Gigabyte website is version 10.800a released (13 august) whereas the latest on the VIA website is ver 10.500d.
I will try both and update with the result.
25 Aug 2012   #20
BaronV
It works!
GOOD NEWS! I just tested the latest 10.800a drivers released just released by gigabyte and now my independent headphones work as they are supposed to!
To the OP just go to gigabyte and download the latest (august 2012) audio drivers and that should solve your problem
Front panel headphone jack problems
I've seen similar posts regarding this, however none have helped so I'm starting my own one...hopefully someone can help. I upgraded from Windows XP to Windows 7 64bit. In XP, I used the front panel headphone jack for hooking up to my TV, or headset. Since I've upgraded, this headphone jack...
Front Panel Headphone Jack - Poor feedback issue
Hi! Thank you for taking the time to read this & hopefully help me resolve my issue. May the records state that I'm not the most experienced with computer hardware, but I'm interested in it and have been learning through my friends. That aside, I recently got a Logitech G230 Stereo Gaming Headset....
Font panel audio not doing as it should with VIA HD audio deck
I recently changed my case and MOBO to a G41M-Combo (Intel). Ive never used front panel before due to not having the option on my sound card. Now that i have this new MOBO it has on board HD 5.1 so im using that to save room on pci slots. I have the options set to notify me when 3.5mm is...
Connecting "HD audio" cable from front panel to sound card
My sound card Xonar D1 doesn't work properly and i wrote to ASUS and they told me to connect the "HD audio" or "speaker" cables from the front panel of motherboard to the sound card's front panel. Is that safe to do? weather it will work or not, is it safe to try?
Connecting Front Panel Audio to Sound Card
I have a front audio panel and a CMI 8738-6ch sound card. The front audio does not work and has a wire coming directly from the back of it with this plug on the end of it... https://lh6.googleusercontent.com/-qn5Chte32nY/T3C78xg6Q9I/AAAAAAAAAIw/Kf0MPEnaTp8/s512/20120326_194826.jpg There are...
front panel headphone socket is dead
Hi all. I am brand new to this forum and Windows 7 so please bear with me as at 73 years old I have never been able to learn computer jargon, my computer is a very old self build that I have extensively upgraded and because the case did not have any front ports at all, not even a headphone...
