Sound Blaster Audigy 2 Platinum ex does not sound in Win7x64
dinorhino
7:32 PM
Hello;
I'm trying to make my "Sound Blaster Audigy 2 Platinum ex" works on Windows 7 64 bits, I did install the most new version of the drivers provided by Creative Labs, it seems like it is installed without any problems....the Device Manager shows all drivers are installed correctly...when I run the audio test the graphic moves like if the soundcard actually works but the real thing is: THERE IS NO SOUND!!, I have done all the tests that Creative labs recommends in their page but I got nothing, please could somebody help me to make this sound card works??
Thank you!
Windows 7 Ultimate x64Intel core i5Corsair 4 gb 1333 MHzIntegrated Graphics Processor
Intel core i5
Asus P8B75-M LE
Creative Soundblaster Audigy 2 Platinum ex
Sony
That is an old sound card and what Creative calls a "legacy" card. Do you have the SB set as the default audio playback device?
Do you have any integrated audio (on the motherboard) devices enabled? If you do, disable that in the BIOS as it can conflict.
Try reseating the sound card (with the PC off) and see if that makes any difference.
Have you tried plugging a headset into the GREEN speaker jack on the rear of the card, in case your speakers are the fault?
Also, please fill in the My System Specs as it helps us to try and help you.
My Own Build
Intel i7 6700K
ASUS ROG Maximus VIII Hero
16GB Corsair Dominator
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
2 TB drive for backup
EVGA Supernova 750G2
BeQuiet Silent Base 600
Deepcool Captain 120EX
Microsoft Wireless 2000
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
Hi, yes I've as the default audio playback, it apparently works OK but the speakers or headset not sound.
I already disabled the onboard audio in the BIOS screen but the SB still not working.
When I tested the sound card plugging the headset or the speaker on the rear output jacks (it has 3) nothing happens, I don't think that the sond card is damaged because it is recognized by the SO also the drivers can detect the device and apparently it works...I'm starting to giving up with this.
I'll try to reseating the sound card hoping this may work.
If there's another option that could help me, will be appreciated.
Thanks again.
Intel core i5
Asus P8B75-M LE
Sony
If reseating does not work, go to the Device Manager, RIGHT click on the entry for the Audigy and then LEFT click "Uninstall" DO NOT check the box to uninstall the drivers. Restart the PC and when Windows starts it will detect and reinstall the sound card. If there was some type of Windows corruption with the sound card this will fix that.
Ultimately it may just be it has a hardware problem and won't work.
My Own Build
Intel i7 6700K
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
Hi, I did the advices you gave me and I had bad luck, on windows xp the sound card used to work but only God knows why it doesn't work on win 7, I hope someone find the answer for that issue
thank you so much
Intel core i5
Asus P8B75-M LE
Sony
