Windows 7: problem with sound
12 Aug 2012   #11
Windows 7 x64
Houston
well you can go here for the via driver
VIA Drivers Download - VIA Technologies, Inc.
The intel one should be supported by windows 7 update.
Check and make sure you aren't missing optional updates that included drivers.
13 Aug 2012   #12
Windows 7 Home Premium 32bit
Maguscreed
Thanks very much, problem is resolved
 problem with sound problems?
Similar help and support threads for: problem with sound
Solved How do i fix the sound problem Sound & Audio
Sound card/sound problem questions? Hardware & Devices
Solved Sound Problem Sound & Audio
Solved Sound problem - need to 'scan for hardware changes' to get sound Hardware & Devices
Windows Media Player Problem - Sound/skipping problem. Music, Pictures & Video
