Solved How do i fix the sound problem
x4gottensoldier
4:38 PM
the sound worked through the tv speakers until i installed a windows update now it does not work. it says the sound is playing and everything is turned up but there is no sound.
Windows 7 64 bit
Windows 7 64 bit
I see four instances of the AMD High Definition Audio device and probably the problem.
You failed to fill ouit the MY System Specs, but I assume you only have one video card.
Suggest you go to the Device Manager and Uninstall ALL the entries for the Video Card (if there is multiple entries). RIGHT click on an entry and then LEFT click "Uninstall". DO NOT check the box to also uninstall the drivers. Do this for each Video card entry listed. You will probably lose the video resolution with uninstalling the video but that will recover. After you have all of the video entries uninstalled, restart the PC and when Windows starts it will detect and reinstall the Video (you may have to reset the resolution after its reinstalled). Then check the playback devices and see if you only have one HDMI output.
My Own Build
Intel i7 6700K
ASUS ROG Maximus VIII Hero
16GB Corsair Dominator
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
2 TB drive for backup
EVGA Supernova 750G2
BeQuiet Silent Base 600
Deepcool Captain 120EX
Microsoft Wireless 2000
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
thanks for your help. it worked
Windows 7 64 bit
Windows 7 64 bit
