Yesterday when I open the computer, I go to Youtube to play a song and, speakers did not go, I play another video and the same thing. It works when I am at mozila firefox and internet explorer. Can someone help me ?
2)Google Chrome is the only one having trouble with audio? other browsers are just fine?
Is this Youtube only? To test if it's just youtube or not please try other sites. Pandora, Soundcloud, any other site you can think of.
3)Make sure the volume is turn up on Windows Volume speaker icon.
When you click on the audio speaker icon you should see something saying "Mixer". Once you click on it find the Google Chrome application and make sure volume for this program isn't turn down.
Computer Type: PC/Desktop System Manufacturer/Model Number: Gateway / Slight Modifications OS: Windows 8 64 bit PRO CPU: AMD Phenom X4 9100e Motherboard: Gateway RS780 Memory: 2GB X2 DDR2 Graphics Card: Sapphire HD 6850 Sound Card: Integrated Monitor(s) Displays: Gateway 19" + Dell 19" Screen Resolution: 1440X900 sometimes 2880 by 900 Keyboard: Saitek Eclipse II Mouse: Gigabyte GM-M6800 PSU: Antec BP 550watts Case: Antec 300 Cooling: Stock Cooling Hard Drives: WD 80GB
WD 640GB
WD 1,000GB Internet Speed: D: 30Mbps U:4Mbps Browser: Internet Explorer ver 10 64 bit Antivirus: Avast version 8 Other Info: This is my work computer.
I have another laptop running Windows 7 64 bit.
Another PC running Windows 8 64 bit pro.
Total of 3
Sorry but its not work i enter in a game after few minutes ago and the sound its work . In game yes . In youtube no.
I think the problem is from google chrome because in mozila, youtube its work
in the chrome it is not work sound of all sites
WD 640GB
Total of 3
