How to keep my surround sound headphones configured to 7.1 not 5.1?
MattSS
10:53 PM
I just got some surround sound headphones. When I restart my computer after having set my sound configuration for the headphones to 7.1 (supported by these headphones) the sound configuration will be at 5.1. I don't know what is causing it to keep going to 5.1. Any ideas on what I can do to fix this so my sound stays at 7.1?
When the set up is at 7.1 the two rear speakers are enabled. This might seem small but I play battlefield 3 and being able to better hear enemies who are behind me will help me play better and this is one of the reasons I got the headphones so I definitely prefer these two speakers to work.
windows 7 home premium 64 bit
There`s no such thing as 7.1 yet, the others channels are just made up from the source audio. Headphones are only 2 channel. No matter what you were told.
Everything is downmixed to 2 channels.
Skylake Special #666
Intel Core i7 6700K
Asus Sabertooth Z170 Mark 1
EVGA GTX 980 Ti SC x2
Realtek High Definition
AOC G2460PG
Logitech G910 Orion Spectrum
Are you sure? When I did the configuration where you can click the individual speakers and listen to which speaker it activated in the headphones, the two additional speakers brought on by 7.1 (the rear ones) sounded distinct when I clicked on them. For this reason I do believe that a 7.1 configuration benefits my headphones.
So considering what I said above, would you say that 5.1 enables those two rear channel speakers in the headphones? (this would mean on a 5.1 setup there would be front center, front right, front left, side left, side right, subwoofer, and rear left and rear right)
5.1 is left, center, right, left rear, right rear, and subwoofer.
7.1 adds left and right sides to the above.
What headset do you have?
Windows 7 Ultimate 64bitIntel i7 3770K16GB DDR3 1333 Corsair XMS3XFX HD6950 2GB EyeFinity
HAL-9000
Intel i7 3770K
Asus Sabertooth Z77
Logitech G35 & Sennheiser PC135 & VIA HD
23" HP 2310e, 23" Samsung B2230, 21.5" Viewsonic
5760x1080
16TB of Storage
128GB & 256GB Crucial M4 SSD's, 2X 1TB WD Black, 3x 2TB WD, 3x 2TB Samsung F4, 1.5TB Seagate, WD 500GB,
Antec True Power New 650watt
Cooler Master HAF-932
Corsair H60 Hydro Cooler, 3x 230mm Fans, 2x120mm Fan
Logitech G15 and G13
Logitech G700 Gaming Mouse
50/10 Mbit
Speakers : Alesis M1 Active Mk2 Studio Monitors , APC RS 1200 UPS, HP 4500DN Color Laser, HP P1006 mono Laser, Kodak 8500 Dye-Sub, Epson 1280 inkjet, Epson Worforce 610 MFC
I have plantronics gamecom 780.
I thought the rear speakers were added by 7.1 because when I toggle between 7.1 and 5.1 in the sound config the rear speakers are the ones that disappear with 5.1.
First off those are not 7.1 headphones. What they are is stereo (only one speaker in each cup), and the 7.1 is done using the Dolbly surround/headphone setting in the heasdsets control panel,
Plantronics Gamecom 780 Review
Note that the software is an integral part of the headsets full functionality and unless you install it you will only be able to use the headphones in stereo mode. Also when the software is not installed, the blue light on the Dolby 7.1 switch stays on constantly as the switch is basically rendered ineffective. There are also none of the audible cue tones when either adjusting the volume or pressing the Dolby 7.1 switch. So as the orange label wrapped around the USB cable warned, install the software first!
Me
Win 7 Ultimate x64
FX-8350 @ 4.6 GHz so far
Asus M5A97 EVO
Sapphire R9 270x Dual-X
Acer S232HL Abid
120 GB OCZ Vertex 3
500 GB Seagate 7200.12
Antec Earthwatts 650W Green
Antec Three Hundred
Cooler Master 212 EVO
Logitech G510
Logitech G500s
