Surround 5.1 problem, Only subwoofer produces sound
z3liorsh
8:26 PM
Hi everybody.
Well i have a stereo 5.1 system by Creative, version SBS 580.
When i first got the computer everything was fine, then my brother bought those headphones, so we didnt use the speakers at all.
so after about 1-2 years without use i plugged them in and tried to use them.
The problem occured was that only the subwoofer worked, none of the speaked did,
and the subwoofer only worked at the "Realtek HD Audio Manager" program.
I tried reading forums of creative, tried to connect the system to the computer in many ways, all of the ways give me the same result, only the subwoofer produces sound.
the way creative's guide say to connect the speakers is like that :
ImageShack® - Online Photo and Video Hosting
The program that im using is "Realtek HD Audio Manager" :
so when i play this play button, only the subwoofer makes the sound, non of the speakers. All of them are connected to the subwoofer correctly, they are turned on.
no technical problems.
Is it a driver's problem?
Please help me, Im exhausted...
Windows 7 Ultimate
Windows 7 Ultimate
As the subwoofer also contains the amplifier(s) and routing of sound, I would suspect that is where the problem is.
You can verify that you are getting audio output from each of the three PC sound connections by hooking a headset to each output and playing audio. If you hear audio (it will only be that channel) from each output then that isolates the problem to the speaker system. On the other hand, if you do not hear audio from all the jacks, make sure 5.1 is set in the Sound Panel, playback section. Click on the speakers icon to highlight it and then click on the Configure button and select 5.1. If that doesn't fix it, reinstall the PC Vendor or motherboard if its a home built system, RealTek audio drivers. They will work better than non-Vendor drivers.
My Own Build
Intel i7 6700K
ASUS ROG Maximus VIII Hero
16GB Corsair Dominator
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
2 TB drive for backup
EVGA Supernova 750G2
BeQuiet Silent Base 600
Deepcool Captain 120EX
Microsoft Wireless 2000
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
