Solved Asus X72VR sound card problems, cooling the chip?
foe
Power User
8:34 AM
Netherlands
Hello everyone!
A few years back my audio jacks started acting weird (one of them being ignored completely) and I've been looking for a solution ever since.
A few days back I disassembled the whole thing and it seems like the jacks itself are still well soldered to the board: it is not caused by the jack itself. Because of this I suspect the Realtek HD sound-chip, often described on fora as a cheap piece of junk.
I must admit I did not look at the chip yet, since I was only looking at the jacks when I disassembled the laptop.
Replacing the chip will be a scary job, since in this case the soldering should be redone. Replacing the mobo crossed my mind, but I guess the stopped selling these and if the still do somewhere it probably wont go cheap.
Anyhow, this guy: No Sound From Headphone Jack With Realtek Hd Audio Device - Single Post said putting the laptop in the freezer will solve a similar problem.
Even if this will help I am worried about the safety of such an action. Of course I could only freeze the mobo and keep everything else out, but I googled around and found people saying the change of temperature might cause chips to break and that the condense could cause short circuit.
So I wondered what do you guys consider the best solution?
BTW I if was possible to only cool the audiochip in stead of the whole mobo :S
Windows 7 x64Intel dualcore P8400 @ 2.26 GHz4G DDR2 SDRAMATI Mobility Radeon HD 3400 Series
Asus X70VR
Windows 7 x64
64-0100-000001-00101111-072208-Cantiga$M70VX2
4G DDR2 SDRAM
Realtek ALC663 @ Intel 82801IB ICH9
LG Philips LP171WP4-TLN1 (or television using HDMI Cable)
Hard Disk Name: Momentus 5400.5 320320
Interface: SATA-II
Formatted Capacity: 320 GB
Max. Internal Data Rate: 490.4 Mbit/s
Buffer Size: 8 MB
RealTek audio is used in many PC's (and on many motherboards). It is as good as any other audio chip. Replacing the chip, if that is really what is needed is not a job for an amateur, you need specialized desoldering and soldering equipment to work on multi-layer circuit boards and Surface Mount Technology (SMT) components. You would need the exact same RealTek chip, as there are many variations of the chip and just using any model chip other than the original will not work.
The best option, if the internal sound is defective is to use a USB connected sound "card".
My Own Build
Intel i7 6700K
ASUS ROG Maximus VIII Hero
16GB Corsair Dominator
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
2 TB drive for backup
EVGA Supernova 750G2
BeQuiet Silent Base 600
Deepcool Captain 120EX
Microsoft Wireless 2000
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
Ok, tnx for the info. I'll leave it out of the fridge then. tnx again
Asus X70VR
Windows 7 x64
4G DDR2 SDRAM
Interface: SATA-II
Buffer Size: 8 MB
