Windows 7: Can no longer find "USB Audio Codec" when device plugged in
20 Aug 2012   #1
RadxBoy
When I right click on the tray speaker icon and select the sound window, I can no longer find the "USB Audio Codec" selection when the device is correctly plugged in. The USB device still works because I can test it on another computer.
It is present in the devices and printers window. Software that used to work with that sound selection no longer work.
Looking hopefully for suggestions. Thank you!
Hank
20 Aug 2012   #2
fireberd
Does it show up in the Device Manager? and if it does, is it shown as working OK or does it have an error code?
If it's shown as working OK int he device manager, it would have to be set as the default audio playback device. Does it show up in the Control Panel/Hardware and Sound and finally the Sound playback panel? If it is not shown, RIGHT click in an empty area in the panel and click to show disabled and disconnected devices and then see if it shows up.
20 Aug 2012   #3
RadxBoy
Thanks for your advice fireberd.
I tried all your suggestions and it just does not show up!
21 Aug 2012   #4
fireberd
Check the USB section in the Device Manager and see if there is an Unknown device listed. If there is, chances are its the USB connected sound device, and the status is corrupted in Windows. If this is the case, RIGHT click on the entry for the device and then LEFT click "uninstall". DO NOT check the box to also uninstall the drivers. Then disconnect the device from the PC and then restart the PC. After Windows starts, reconnect the device and Windows should find the new hardware and reinstall it. Then check the Device Manager and it should be shown under "Sound, Video and Game Controllers".
21 Aug 2012   #5
RadxBoy
Thanks again, fireberd. I did as you suggested but it is not installing correctly...
Can no longer find "USB Audio Codec" when device plugged in-unsuccessfull.png
This is what the device manager window looks like (as you thought)...
Can no longer find "USB Audio Codec" when device plugged in-other-devices.png
Now the truth comes out ... Just before I started having this trouble, in the sounds window you get when right clicking the speaker icon in the task bar, under playback and recording, I thought I would be clever and change the name of the device from "USB Audio Codec" to "SignaLink" (the actual name of the device). It worked OK for awhile, but after restarting the pc, the "USB Audio Codec" disappeared from the sounds window as well as "SignaLink."
So I think that's what I did to screw it up. I tried to restore to a previous time but those all failed ("failed to extract c:\config.msi from the restore point").
What do I do next?
21 Aug 2012   #6
fireberd
Not sure what you will have to do to get it to work. Uninstall it in the Device Manager and also check the box to uninstall the drivers this time. Disconnect the device, restart the PC and after Windows starts reconnect it and see if Windows can install it.
21 Aug 2012   #7
RadxBoy
Apparently, there is a problem installing the drivers...
Can no longer find "USB Audio Codec" when device plugged in-device-manager.png
I cannot even update the driver, even when going on line....
Can no longer find "USB Audio Codec" when device plugged in-problem-installing-driver.png
I'm beginning to feel like I'm hosed.
Do you think a possible solution lies in the registry?
More suggestions?
Thank you!
Can no longer find "USB Audio Codec" when device plugged in-usb-audio-has-problem.png
22 Aug 2012   #8
fireberd
Does the USB sound unit Vendor have a driver for this? That would be the next step (question).
22 Aug 2012   #9
RadxBoy
No, the vendor says it uses the generic microsoft driver usbaudio.sys which is present and accounted for. I have tried Windows update with no improvement.
22 Aug 2012   #10
fireberd
Last shot. Does HP have any motherboard chipset drivers? If they do install them and see if it helps.
Nvidia HDMI "not plugged in" (greyed out), video, but no audio
Hi all, Here's my setup: Nvidia video card>HDMI out to Sony Home Theater System>HDMI out to Samsung HDTV. I use this to get 5.1 LPCM surround sound for video games. It worked fine until I did a firmware update on the Sony unit. Now, the HDMI audio is greyed out in Windows 7 audio playback...
Realtek HD Audio - Speakers "Not plugged in"
Hello, I'm new. So sorry if I do not post in the common format. Recently, I had downgraded to Win 7 Ultimate from Windows 8, for various reason. So I do my normal things, download all the drivers, and programs that I would need. Sadly, I had lost my motherboard's drivers disc. So, having...
need "always on top icon & msg for "default audio input/output device"
I need to always display the default audio input and audio output device currently on win7. Would like to launch a small program on change as well or instead. I tried to use task scheduler but was not able. Help! Thanks, Ray
"Unable to find a compatible SRS Audio Device."
I have an Asus k60ij laptop and all of a sudden this message appears when I boot up my CPU. I have recently wiped out my CPU. I have gone onto the Asus site and cant seem to find it. My CPU says that the mic is working properly but it doesn't pick up sound...my speakers and other sound seems to...
"Could not find this item." "This is no longer located in _____....."
"Could not find this item." "This is no longer located in C:/Users/Amber/My Pictures. Please verify the items location and try again." How do you delete the file? it was a picture, but now it's like a blank white paper looking thing. i just want it OUT of my pictures file. No, i cannot move it...
Music, Pictures & Video
Audio devices "not plugged in" when they are
Windows seems to believe any audio device I plug in isn't actually plugged in. No matter which jack I plug anything into, it doesn't detect either my mic, my monitor speakers, or my headphones. I updated to the Vista version of the realtek drivers, and it doesn't detect anything either. I don't...
