Windows 7: sound signal does not appear on task bar in W7
23 Aug 2012   #1
nrimawi
windows 7 Ultimate
Hi
I lost my sound sign on task bar( sound signal does not appear on task bar in W7-Ultimate-)
please advice
Thanksssssssssss milliomssssss
23 Aug 2012   #2
Sardonicus
Windows 7 Home Premium 64 bit
Need help creating a task scheduler task to move files over a network.
Hello everyone, I need to have a task run that will move the contents of a folder from one computer to another over my home LAN. Files get downloaded during the night on one computer and then need to be transfered to another. Usually I am doing this by hand, but then though maybe I could get...
General Discussion
Task scheduler unable to load task status/active tasks at startup.
My task manager is unable to load task status/active tasks at startup. I get the message: "The selected task "{0}" no longer exists. To see the current tasks, click Refresh." When I refresh I get the same message. I checked and found that under Microsoft the problem was in the defrag...
Performance & Maintenance
Mutliple Outlook 2003 instance in task tray and task manager
Every now and then I look down at the task tray ...and whoa!!!! about a dozen instances of Outlook. See attached What is causing this? And how do I prevent it??
Microsoft Office
Task Scheduler failing to start task with merged network locations
I have two routers I usually connect to (work and home) and each have wireless access. That means there are essentially 4 network locations I have listed. I have merged each respective network location (wired and wireless) into their own singular network location - "Work" and "Home". I also...
General Discussion
WMC and TV Tuner - No Signal / Too Weak a Signal
I have owned several TV Tuners in the past and this is the first OS that has given me problems. I have a Hauppauge WinTV-HVR-1950 (USB 2.0hs) and cannot get a picture from my Cox Cable Service in Orange County, Southern CA. Installed the 64bit driver from Hauppauge. According to Device...
Media Center
hp pavilion no sound-red x over speaker in task bar
I downloaded and installed windows 7 from the microsoft site, now my sound won't work. I tried updating it but nothing. I have the latest realtek drivers AC'97 audio and the high definition audio in the device manager but both have a yellow exclamation mark next to them. Then when I click on it, it...
