headphones does not work
  1. Posts : 13
    window 7
    win xp was pre-installed on my pc. but last month i got a cd of win 7 from my friend and i installed win 7 on my pc. after installing everything is working fine i got no problem. speakers audio video devices are all working good. but headphones are not working i didnt know the solution. someone help me plz
    Please fill in the "My System Specs" all we can do is guess without that information.
  3. Posts : 13
    window 7
    there r so many thing in SPECS those i does not what to fill. tell me main the thing u want to know so that u can solve my problem, why my headphone does not works in win 7 but works in win xp
  4. Posts : 11
    windows 7 ultimate 32 bit
    Hey try this :
    1. Right click your speakers
    2. Click playback devices
    3. Right click Head phones and click enable.
  5. Posts : 8,135
    We need enough information to try and assist you. Since it worked in XP, we need to know the PC Vendor and model number so we can see if its Windows 7 compatible. There are many older PC's that are not Vista/Windows 7 compatible as the PC vendor has not made Vista/Win 7 drivers available.
  6. Posts : 13
    window 7
    operating System: Win 7 Ultimate 32-bit (6.1, Build 7600) (7600.win7_gdr.120305-1504)
    Language: English (Regional Setting: English)
    System Manufacturer: ECS
    System Model: G31T-M7
    BIOS: Default System BIOS
    Processor: Pentium(R) Dual-Core CPU E5400 @ 2.70GHz (2 CPUs), ~2.7GHz
    Memory: 1024MB RAM
    Available OS Memory: 1014MB RAM
    Page File: 941MB used, 1096MB available
    Windows Dir: C:\Windows
    DirectX Version: DirectX 11
    DX Setup Parameters: Not found
    User DPI Setting: Using System DPI
    System DPI Setting: 96 DPI (100 percent)
    DWM DPI Scaling: Disabled
    DxDiag Version: 6.01.7600.16385 32bit Unicode
    may be this can help u to find solution of my problem
    i checked my headphones r working but in the speakers panel, not in own panels
  7. Posts : 2
    Windows 7 64 bit
    Any solutions?
  8. Posts : 8,135
    I checked the ECS site for the motherboard.
    There are chipset drivers and VIA sound drivers. Suggest you install both - the chipset drivers first then the VIA sound drivers and see if that helps. ECS Web Site > G31T-M7 (V7.0)
    As a side note, with only 1GB of RAM, I would suggest upgrading, at least to 4GB. If you wanted to run Windows 7 64 bit, I would go with 8GB of RAM. The 1GB is bare minimum.
