Realtek AC'97 Audio - Cant hear any sound from headphones or speakers.
ms200592
12:19 AM
I just bought a pc, windows 7 32bit. I tried to use my headphones but couldnt hear any sound, also tried speakers still no sounds. The green bar goes up on the volume control tho.
I have tried downloading some drivers, but they didnt work.
Im a novice when it comes to things like this, can anyone help?
if you need any information about my pc let me know.
theres some audio ports at the back of the pc and at the front. both dont work.
Thanks if anyone can help, i really dont know what to do
Windows 7 32bit
Windows 7 32bit
Anyone?
Windows 7 32bit
Windows 7 32bit
If you right-click on the speaker icon in the System Tray and select "playback devices", what options are presented to you? What items are in the list of available output sound playback devices?
Which one has the green check (i.e. currently selected as "default")? It should be "speakers" if you have your L/R speakers connected to the [usually] green jack on the motherboard or sound card and want sound from them.
If "speakers" is shown but is not checked as the current default, when you select it and push the "set default" button at the bottom of the dialog, do you now have sound coming out of your speakers? Does that solve your problem?
Windows 7 Pro x64 (1), Win7 Pro X64 (2)i5-3350p 3.1Ghz/6MB-cache (1); E8400 3.0Ghz/6...8GB PC3-12800 DDR3 (1); 4GB PC3-10600 DDR3 (2)ATI HD7750 (1), (see TV cards); ATI R7 250 (2)
Home-built, two systems (1) and (2)
i5-3350p 3.1Ghz/6MB-cache (1); E8400 3.0Ghz/6MB-cache (2)
ASUS P8Z77-V Pro (1); ASUS P5Q3 (2)
Realtek ALC892 HD Audio (1); Realtek ALC1200 HD Audio (2)
Eizo HD2441W LCD, Eizo S2433W (1); Eizo 24" S2433W (2)
1920x1200, 1920x1200 (1); 1920x1200 (2)
(1) 1TB SATA-II (7200RPM), 2x2TB SATA-III (7200RPM), 250GB SATA-III (10000RPM) for OS; 2x2TB external USB 3.0
(2) 320GB SATA-II (7200RPM), 750GB SATA-II (7200RPM), 150GB SATA-II (10000RPM) for OS; 2TB external USB 3.0
Nesteq ECS-6001 600W (1); Nesteq ECS-5001 500W (2)
Acousti-Case 360 (1) and (2)
Noctua NH-U12P SE2 for CPU, 2x120mm case fans (1) and (2)
IBM PS/2 (1) and (2)
Logitech MX Revolution wireless (1); Microsoft wired (2)
100mbps down / 10mbps up
Microsoft Security Essentials; Malwarebyte Anti-Malware Pro
Ceton InfiniTV 4-tuner cablecard-enabled TV card as well as Hauppauge HVR-2250 OTA/ATSC 2-tuner TV card in (1), running under Win7 WMC
I think the speakers are set to default, i tried plugging the speakers into the front & back green audio port but still no sound.
Windows 7 32bit
Windows 7 32bit
I just re-installed the drivers but i still have no sound.
Windows 7 32bit
Windows 7 32bit
Did you solve this?
Windows 7 Ultimate x64AMD Athlon 64 3500+DDR,Dual,4096MBytesATI Radeon HD 4350, 512MB
Custom build
AMD Athlon 64 3500+
MSI MS-7125
DDR,Dual,4096MBytes
SAMSUNG HD642JJ ATA Device
Internet Explorer,Firefox Developer Edition
