X-Fi Titanium HD looses sound.
  1. Posts : 17
    Microsoft Window 7 Home Premium 64bit
    Hello everyone! I have a Creative Sound Blaster Titanium HD PCI Express card and finding out every couple days I have to reinstall the drivers in order to have sound. I can't seem to find why this happens. This is really getting annoying. Does anyone have this problem? Is there a fix or is this a sign my card is failing?
    Thank you :)
    Do you have the Integrated (on the motherboard) audio disabled in the BIOS? If not give that a try, could be a conflict causing the problem if its not disabled.
  3. Posts : 17
    Ok I disable the on board sound. Hopefully this will work.
    Thanks for the help fireberd
  4. Posts : 8,135
    Let me know, I'll keep this thread on my watch list
  5. Posts : 17
    Well It seems that the sound stay after shutting pc off and starting up again the day after.
    Thank for your help :)
  6. Posts : 8,135
    Great. Sounds like the problem has been resolved.
