No sound from Inegrated Audio
  1. Posts : 5
    Windows 7 Home Premium X64
    Hello all I am a newbie here, I know somewhat about computers, but anyway all of a sudden my on board audio has stopped working, I did some research on some other reads they all so to uninstall, install audio drivers, trying different speakers and I get a static sound like a hissssss/ . I have en checked the inside and there is no sign of anything.
    This is so frustrating I cant hear squat just that annoying hiss sound, any help please.
    System Manufacturer: Microsoft Corporation
    System Model: p6751c
    Processor: AMD Phenom(tm) II X4 830 Processor, 2800
    BIOS Version/Date: American Megatrends Inc. 6.11, 12/28/2011
    SMBIOS Version: 2.6
    RAM: 6GB
    Total Physical Memory: 5.75 GB
    Available Physical Memory: 4.29 GB
    Total Virtual Memory: 11.5 GB
    Available Virtual Memory: 9.64 GB
    Do you get the same "hiss" on both speakers and headphones? Or just with speakers?
  3. Posts : 5
    Thanks for the reply, when I plug in the headphones and speakers in the back I get the hiss sound, but when plug it in to the front jacks I get no sound at all, it detects it because I an adjust the volume but no sound.
    Have you uninstalled and re-installed the drivers?
  5. Posts : 8,135
    Before you reinstall the drivers, try a System Restore back to a date when it did work properly, since this problem is recent. If that doesn't work then reinstall the drivers from HP. (Vendor sound drivers are preferred over generic Windows drivers or non-vendor drivers).
    System Restore can be accessed from Start/Programs/Accessories/System Tools.
  6. Posts : 5
    Ok first I did a system restore, still no sound. I installed-reinstalled drivers and still no sound, I am so angry !
  7. Posts : 2,240
    Windows 7 Ultimate 64 bit
    What type of speakers are you using?
  8. Posts : 5
    Idk some hp speakers that came with the computer, I treid using others speakers some GEM 2.0's
  9. Posts : 8,135
    Based on what you have tried, it sounds like there could be a hardware problem with the integrated audio chip. If that is the case, and its still under warranty, contact HP support. If its out of warranty, consider installing a separate sound card and using that, as the only other option is to replace the motherboard.
  10. Posts : 5
    Thanks for the help guys . I guess I have to buy a new sound card
