Windows 7: No sound from Inegrated Audio
03 Sep 2012   #1
Gyneco
Windows 7 Home Premium X64
Hello all I am a newbie here, I know somewhat about computers, but anyway all of a sudden my on board audio has stopped working, I did some research on some other reads they all so to uninstall, install audio drivers, trying different speakers and I get a static sound like a hissssss/ . I have en checked the inside and there is no sign of anything.
This is so frustrating I cant hear squat just that annoying hiss sound, any help please.
System Manufacturer: Microsoft Corporation
System Model: p6751c
Processor: AMD Phenom(tm) II X4 830 Processor, 2800
BIOS Version/Date: American Megatrends Inc. 6.11, 12/28/2011
SMBIOS Version: 2.6
RAM: 6GB
Total Physical Memory: 5.75 GB
Available Physical Memory: 4.29 GB
Total Virtual Memory: 11.5 GB
Available Virtual Memory: 9.64 GB
04 Sep 2012   #2
fireberd
Do you get the same "hiss" on both speakers and headphones? Or just with speakers?
04 Sep 2012   #3
Gyneco
Thanks for the reply, when I plug in the headphones and speakers in the back I get the hiss sound, but when plug it in to the front jacks I get no sound at all, it detects it because I an adjust the volume but no sound.
05 Sep 2012   #4
x BlueRobot
Have you uninstalled and re-installed the drivers?
05 Sep 2012   #5
fireberd
Before you reinstall the drivers, try a System Restore back to a date when it did work properly, since this problem is recent. If that doesn't work then reinstall the drivers from HP. (Vendor sound drivers are preferred over generic Windows drivers or non-vendor drivers).
System Restore can be accessed from Start/Programs/Accessories/System Tools.
05 Sep 2012   #6
Gyneco
Ok first I did a system restore, still no sound. I installed-reinstalled drivers and still no sound, I am so angry !
05 Sep 2012   #7
bassfisher6522
Windows 7 Ultimate 64 bit
What type of speakers are you using?
06 Sep 2012   #8
Gyneco
Idk some hp speakers that came with the computer, I treid using others speakers some GEM 2.0's
06 Sep 2012   #9
fireberd
Based on what you have tried, it sounds like there could be a hardware problem with the integrated audio chip. If that is the case, and its still under warranty, contact HP support. If its out of warranty, consider installing a separate sound card and using that, as the only other option is to replace the motherboard.
08 Sep 2012   #10
Gyneco
Thanks for the help guys . I guess I have to buy a new sound card
No sound from onboard audio (Realtek High Defition Audio)
Hey Guys, So here it goes, I normally have my Logitech z-5500 speakers connected to the onboard sound output (green,yellow and black) as well as my Plantronics 780 connected to the front panel USB port. I used to be able to play music through any one without any problems, just had to select...
No sound on Sound Blaster X-Fi Xtreme audio
Hello guys, Last night I was helping to a friend and connected his computer with mine by KVM switch. We had done all, I got unplugged KVM switch,reconnected my monitor,KB an mouse.Everything was just fine. After a while,without reason, (or there may be some reason which I can't figure...
VIA High Definition Audio ,no sound digital audio (S/PDIF)
Motherboard :asus p5kpl-am se (no sound card) vendor id :1106 device id :0397 problem: digital audio (S/PDIF) no sound OS : Windows 7 ultimate 32bit i've download numerous latest driver on the official website of VIA and installed it, yet no different.. i wonder if anybody can help me with...
No sound via audio jacks, but sound via hdmi.
I recently done a new build, not with the same specs I have on here; i5 2500k p8z77-m pro sapphire radeon 6870 I cannot get any sound through the front+back headphone jacks, realtek doesnt detect any audio devices, however i can mess around with the settings to get windows to say i have...
start navigation sound (continuation from Sound & Audio)
continuation from this thread: http://www.sevenforums.com/sound-audio/107468-start-navigation-sound-playing-no-reason.html here's the Highjack log file:
System Security
IDT High Def Audio, buzzing sound when playing any sort of audio.
Hello, Starting about a week ago whenever any audio is being played through my computer (speaker or headphone) I will hear a buzzing sound and occasionally the audio with skip. This happens weather I am playing audio that is being streamed from the internet or that is on my computer directly....
