Stuttering sound + Sound mixer "System Settings" flashing in and out
  1. Posts : 7
    64bit Windows 7 Ultimate
    This is a weird issue I'm having. I did a restart and when I came back BF3 wasnt playing any sounds, which is weird because it was just working.
    I went to make sure it wasnt muted in the mixer, and I see the weirdest thing.
    The application "System Sound" is disapearing in and out very quickly, not only in the mixer but In devices as well
    What can I do to fix it? Maybe reinstall w7 sound drivers?
  2. Posts : 1,641
    Dual-boot: Windows 7 HP 32-bit SP1 & Windows XP Pro 32-bit SP2.
    What soundcard have you got?
  3. Posts : 7
    Sorry should have mentioned, I'm using sound from the motherboard, but have noting plugged into it. My headset is a Gamecome 780 which runs via USB
    Also when I try doing something such as Properties or disabling on the Sound screen from control panel it crashes saying: Windows Shell Common DL has stopped working
  4. Posts : 1,641
    Have you installed anything recently, also have you tried system restore?
  5. Posts : 7
    Everything has been installed properly, and I had just done a system restore a bit back. Are there some other things I can try before doing a restore?
