Stuttering sound + Sound mixer "System Settings" flashing in and out
DigitalRicky
4:49 PM
This is a weird issue I'm having. I did a restart and when I came back BF3 wasnt playing any sounds, which is weird because it was just working.
I went to make sure it wasnt muted in the mixer, and I see the weirdest thing.
The application "System Sound" is disapearing in and out very quickly, not only in the mixer but In devices as well
What can I do to fix it? Maybe reinstall w7 sound drivers?
64bit Windows 7 UltimateI7 260016GBEVGA Geforce GTX 680 4gb
I7 2600
MSI Z77A-g45
16GB
None
Catleap q270 + LG 1080p
2560x1400 + 1920x1080
500GB
Antec 750w
Antec eleven hundred
Corsair H60
Mac Aluminum
Razer Deathadder
12mbs down + 1.5mbs up
What soundcard have you got?
Dual-boot: Windows 7 HP 32-bit SP1 & Windows ...AMD Phenom X4 9550 2.8Ghz4.0GB RAM256MB On-board ATI Radeon X1200 Series
Advent
Dual-boot: Windows 7 HP 32-bit SP1 & Windows XP Pro 32-bit SP2.
FOXCONN A6VMX (Socket 940)
4.0GB RAM
UnKnown
19" TFT Mointor
1400 by 900
500GB Western Digital WDC
HP Keyboard
Dial-up via Mobile phone (Three)
80GB External Hard-drive.
Also I have an old Windows XP Laptop for backup/occasional use etc.
Sorry should have mentioned, I'm using sound from the motherboard, but have noting plugged into it. My headset is a Gamecome 780 which runs via USB
Also when I try doing something such as Properties or disabling on the Sound screen from control panel it crashes saying: Windows Shell Common DL has stopped working
I7 2600
MSI Z77A-g45
16GB
None
500GB
Antec 750w
Corsair H60
Mac Aluminum
Razer Deathadder
Have you installed anything recently, also have you tried system restore?
Advent
4.0GB RAM
UnKnown
19" TFT Mointor
1400 by 900
HP Keyboard
Everything has been installed properly, and I had just done a system restore a bit back. Are there some other things I can try before doing a restore?
I7 2600
MSI Z77A-g45
16GB
None
500GB
Antec 750w
Corsair H60
Mac Aluminum
Razer Deathadder
