Windows 7: noise from lineout, problem with Realtek ALC1200 Audio V6
07 Sep 2012   #1
itman
windows 7 ultimate x86
Hi everyone
I have Asus p6t mainboard, There has been noise on lineout, in windows XP I used Realtek ALC1200 Audio V5 mixer to mute some lines and noise disappeared.
but windows 7 uses Realtek ALC1200 Audio V6 and there is no mixer (at least i couldn't find) there.
How can I solve this problem?
08 Sep 2012   #2
fireberd
This sounds like a hardware problem with the sound chip, since you had the noise in XP but were able to mute it (not fix it).
Realtek HD Audio Manager, Buzzing noise in playback
I've got a headset with a mic and In the Audio Manager i've got the playback volume muted. When i un-mute it there is a faint buzzing noise. thats not a big problem but when i want to talk to friends on skype. I'm really quiet and they can hear the buzzing noise. When I try to use the Microphone...
Realtek ALC1200: How can I get 5.1 audio from optical?
I have an ASUS P5Q3 motherboard, with Realtek ALC1200 onboard sound. Latest 2.70 Realtek driver (6/19/2012, 6.0.1.6662). Video card is ATI HD5770, which includes dual-DVI as well as HDMI. I'm using the two DVI outputs to support two 24" LCD monitors. Latest 12.8 Catalyst driver. Up until...
A zoom (White noise?) i cant get rid of, Audio problem?
Hi there, i got this problem since i reinstalled windows ultimate on my laptop. I tried reinstalling windows, tryed different drivers and still i cant get it to stop. My laptop cable is connected on to a screen and the plugs are in a grounded outlet.. This sound only comes up when i get...
Static noise on my realtek HD audio
When I pause any audio on my PC I always hear weird noise, like a mosquito, it's so annoying. If you mute - sound disappears, but the more volume you put the louder it is. Any one had similar problems? Or this just means that i need a better audio card?
Realtek HD Audio problem
Hi, I'm having a few problems with certain sound drivers in windows 7. I recently done a clean install of Windows 7 and my sound is quite crackly. In Vista everything was fine and I had the Realtek HD audio software installed. Now whenever I try to install the same software it says there is...
Audio noise when first sound is played built-in Realtek
Hello. I want to ask a question about my problem. I tried to search about my case, but it's seems I'm the only one in this world who has problem like that. I have Asus P2W DH Deluxe motherboard with buit-in Realtek audio card (ALC882). My 5.1 audiosystem is connected via analog outputs. A...
