Windows 7: Sound static problems!
14 Sep 2012   #11
fireberd
I use the free Microsoft Security Essentials for Antivirus and it does not cause any clicks or DPC latency spikes. The Microsoft Security Essentials is one of the higher rated Antivirus programs, too.
Static for all sound
so last night I went to sleep with perfect working sound. today I came home from work and static plays every time i try to listen to music or audio clips.
Help with static sound
i have a 5.1 surround sound system and for some reason all the sound coming out of the speakers is mixed in with static noise. recently i completely formatted my hard drive (you can check the link here) i reinstalled my sound driver (Realtek) but i still have the same issue. any help? my...
Sound static/ lag
When listening to music in WMP, or watching a video using flash I get static and sometimes lag when I use the PC. I do not know why, can someone help? Its mainly when i do something such as refresh a web page, click a new tab, its not all the time but sometimes.
Sound Static Help (removes most static)
Stumbled upon this trying to fix my static and it helped it out a bit, not 100% though but thought i would share it. Anyways; goto your playback devices > click your speaker properties > advanced > and change the default format to a higher setting, such as 24 bit, 48000hz (studio quality) ...
Realtec Sound card. Fuzzy/static sound
ive updated all the drivers and still get the same prob. this is in windows 7. So i am out of things to try. first bug ive run in to and its a big one at that. apart from that windows 7 is damn hot
Realtek sound fuzzy/static
Hi, I have been trying out RC 7100 and 7229 with a AMD/ATI 780G mobo with realtek HD audio. I have tried up to driver version 2.26 (have 2.27 now, will try when at home later). I am using 2.1 speakers from the green analog connection. My issue is this: I get a static/fuzzy sound. The sounds...
