| Windows 7: Sound static problems! |
12 Sep 2012
#1 | | Windows 7 Home Premium x64 Jackson, Michigan |
Sound static problems! I've had my laptop since April. About a month ago, I noticed the sound was crackling and popping. It mostly happens on Google Chrome. I can have a video or song playing and if I go to another tab, the sound stops and and starts and crackles. I download DPC Latency Checker. I've noticed that when the sound crackles and pops, the latency spikes. I've tried uninstalling the sound driver (Realtek High Definition) and reinstalling to no avail. I even conisidered that Flash is the problem. I've updated Flash and it didn't fix anything either. How can I fix this issue? | My System Specs |
| System Manufacturer/Model Number Acer Aspire Z1620 All-In-One OS Windows 7 Home Premium x64 CPU Intel Celeron G530 Motherboard N/A Memory 2GB DDR3 Graphics Card Intel HD Graphics 1000 (GT1) Sound Card Realtek High Definition Audio Monitor(s) Displays AIO Monitor Screen Resolution 1600 x 900 Hard Drives 500gb SATA |
13 Sep 2012
#2 | | Windows 7, 64 bit Home SP1, Win 8 Pro 64 bit Citrus Co, FL |
Popping and crackling is a frequently posted problem. Unfortunately there is no "one fix" for the problem. Drivers are one issue. Use the Samsung provided RealTek driver, do not use one obtained from somewhere else or what Windows will install. Video drivers can be another issue. Although you have a laptop and probably connecting to the internet via wi-fi, the wi-fi device/connection can be another issue.
Running processes can be another cause. I had a DPC latency issue with a new desktop build that turned out to be a program that was monitoring the PC health. After I uninstalled that program the DPC latency spikes went away. So, check what is in the startup or what is in the Notification Area (lower right).
There have been many posts on here (and other forums) about this. | My System Specs | | Computer type PC/Desktop System Manufacturer/Model Number My Own Build OS Windows 7, 64 bit Home SP1, Win 8 Pro 64 bit CPU Intel i7 3770 Motherboard Gigabyte GA-Z77X-UD5H Memory 16GB GSkill Ripsaw F3-14900CL9Q-16GBXL Graphics Card Sapphire HD7770 Sound Card RealTek Monitor(s) Displays Viewsonic VA2448 Series 24" LED Screen Resolution 1920X1080 Keyboard Kensington wired Mouse Logitech Wireless PSU Antec High Current Gamer HCG-620M Modular Case Coolermaster HAF XM Cooling Corsair H80 Liquid cooling with aftermarket Nexus quiet fans Hard Drives 240GB Intel 520 SSD for Win 7
128GB OCZ Vertex 4 SSD for Win 8
1 TB Seagate drive for backup Internet Speed 40 MB/sec (Cable) Antivirus Microsoft Security Essentials and Malwarebytes Browser I.E9/Firefox Other Info Sonar X2 Professional 64 bit Recording Software with Roland Octa-Capture and MAudio Fast Track Ultra 8R recording interfaces, Frontier Tranzport wireless control unit, Behringer BCF2000 Control Surface.
Five USB connected optical drives for CD Audio production using Nero 11
Other systems: Desktop with i5 3550 CPU, LenovoZ560 Laptop with Win 7 64 bit HP, SP1, new iPad |
13 Sep 2012
#3 | | Windows 7 Home Premium x64 Jackson, Michigan |
So I think I've figured out what's been causing the spikes. I disabled my wireless adapter and everything was good. I enabled it and it started spiking again. I also noticed that it spikes when I'm on YouTube or watching any other flash video. Could flash cause the problem? | My System Specs | | System Manufacturer/Model Number Acer Aspire Z1620 All-In-One OS Windows 7 Home Premium x64 CPU Intel Celeron G530 Motherboard N/A Memory 2GB DDR3 Graphics Card Intel HD Graphics 1000 (GT1) Sound Card Realtek High Definition Audio Monitor(s) Displays AIO Monitor Screen Resolution 1600 x 900 Hard Drives 500gb SATA |
13 Sep 2012
#4 | | Windows 7, 64 bit Home SP1, Win 8 Pro 64 bit Citrus Co, FL |
If you enabled the wireless so you can access YouTube you are back to the same spike problem. Are you close enough to the modem or router to connect with a cable and disable the wireless adapter?
Its not a flash problem, or at least none of the problems/solutions posted have been a flash related problem. | My System Specs | | Computer type PC/Desktop System Manufacturer/Model Number My Own Build OS Windows 7, 64 bit Home SP1, Win 8 Pro 64 bit CPU Intel i7 3770 Motherboard Gigabyte GA-Z77X-UD5H Memory 16GB GSkill Ripsaw F3-14900CL9Q-16GBXL Graphics Card Sapphire HD7770 Sound Card RealTek Monitor(s) Displays Viewsonic VA2448 Series 24" LED Screen Resolution 1920X1080 Keyboard Kensington wired Mouse Logitech Wireless PSU Antec High Current Gamer HCG-620M Modular Case Coolermaster HAF XM Cooling Corsair H80 Liquid cooling with aftermarket Nexus quiet fans Hard Drives 240GB Intel 520 SSD for Win 7
13 Sep 2012
#5 | | Windows 7 Home Premium x64 Jackson, Michigan |
I connected my laptop to my router and the spikes aren't as frequent. There's one every once in a while but they aren't nearly as bad. So I guess that means the problem is my wireless adapter. What can I do to fix the problem with my wireless adapter? | My System Specs | | System Manufacturer/Model Number Acer Aspire Z1620 All-In-One OS Windows 7 Home Premium x64 CPU Intel Celeron G530 Motherboard N/A Memory 2GB DDR3 Graphics Card Intel HD Graphics 1000 (GT1) Sound Card Realtek High Definition Audio Monitor(s) Displays AIO Monitor Screen Resolution 1600 x 900 Hard Drives 500gb SATA |
13 Sep 2012
#6 | | Windows 7 Home Premium x64 Jackson, Michigan |
Nevermind! The spikes just started again and they are BAD!!! I've never seen them this bad before. I don't know what the problem is. | My System Specs | | System Manufacturer/Model Number Acer Aspire Z1620 All-In-One OS Windows 7 Home Premium x64 CPU Intel Celeron G530 Motherboard N/A Memory 2GB DDR3 Graphics Card Intel HD Graphics 1000 (GT1) Sound Card Realtek High Definition Audio Monitor(s) Displays AIO Monitor Screen Resolution 1600 x 900 Hard Drives 500gb SATA |
14 Sep 2012
#7 | | Windows 7, 64 bit Home SP1, Win 8 Pro 64 bit Citrus Co, FL |
Did you disable the wireless adapter, either in the Device Manager or BIOS, when you used the cable connection? | My System Specs | | Computer type PC/Desktop System Manufacturer/Model Number My Own Build OS Windows 7, 64 bit Home SP1, Win 8 Pro 64 bit CPU Intel i7 3770 Motherboard Gigabyte GA-Z77X-UD5H Memory 16GB GSkill Ripsaw F3-14900CL9Q-16GBXL Graphics Card Sapphire HD7770 Sound Card RealTek Monitor(s) Displays Viewsonic VA2448 Series 24" LED Screen Resolution 1920X1080 Keyboard Kensington wired Mouse Logitech Wireless PSU Antec High Current Gamer HCG-620M Modular Case Coolermaster HAF XM Cooling Corsair H80 Liquid cooling with aftermarket Nexus quiet fans Hard Drives 240GB Intel 520 SSD for Win 7
14 Sep 2012
#8 | | Windows 7 Home Premium x64 Jackson, Michigan |
Yes, I had disabled it. It seems it's not the problem though. I was guessing that Avast was causing the problems so I uninstalled it and installed AVG. I was right! There's still a sound pop here and there but it's slowly getting better and I can actually use my computer now. | My System Specs | | System Manufacturer/Model Number Acer Aspire Z1620 All-In-One OS Windows 7 Home Premium x64 CPU Intel Celeron G530 Motherboard N/A Memory 2GB DDR3 Graphics Card Intel HD Graphics 1000 (GT1) Sound Card Realtek High Definition Audio Monitor(s) Displays AIO Monitor Screen Resolution 1600 x 900 Hard Drives 500gb SATA |
14 Sep 2012
#9 | | Windows 7 home premium x64 |
Hi, I don't know if I've missed something but just out of interest, is the laptop on battery or mains adapter, if on mains does the problem persist when running on battery? | My System Specs | | System Manufacturer/Model Number DIY OS Windows 7 home premium x64 CPU AMD FX-4100 AM3+ 3.6GHz 12MB Black Edition Motherboard Asus M5A97 Pro Memory Crsair vengeance 12Gb DDR3 1600MHz CL9 Graphics Card Asus GTX 560 1GB Sound Card Realtek onboard Monitor(s) Displays Hanns G 1680x1050 native PSU OCZ StealthXstream II 500W Hard Drives OCZ 128Gb Petrol ssd
2x500 Gb Samsung Internet Speed 8Mb or better |
14 Sep 2012
#10 | | Windows 7 Home Premium x64 Jackson, Michigan |
The problem happened whether it was on AC power or battery. | My System Specs | | System Manufacturer/Model Number Acer Aspire Z1620 All-In-One OS Windows 7 Home Premium x64 CPU Intel Celeron G530 Motherboard N/A Memory 2GB DDR3 Graphics Card Intel HD Graphics 1000 (GT1) Sound Card Realtek High Definition Audio Monitor(s) Displays AIO Monitor Screen Resolution 1600 x 900 Hard Drives 500gb SATA Sound static problems! problems? All times are GMT -5. The time now is 04:35 AM. | |
