Realtek HD Audio EQ settings problem
  1. Posts : 6
    Hello. :)
    i have a problem with Realtek Preset EQ
    when i change the EQ settings .. it works perfectly while playing a song
    but when i close the audioplayer and restart it again the EQ settings back to it's default
    so.. how can i save this settings and make it work everytime i lunch a media palyer?
  2. Posts : 6
    up up up
  3. Posts : 2,752
    After you make your EQ setup, there is a SAVE button to the right of the sliders.
    Push that SAVE button, and then enter the name you want to save the EQ setup as. That setup will remain in effect until you change it.
    You can save any number of EQ setups, and you will also be able to re-load them by name.
    NOTE: You will lose all of your saved EQ setups whenever you upgrade Realtek audio drivers to a new version. That's because the so-called "upgrade" actually consists of two steps: (a) UNINSTALL current driver, and (b) INSTALL new driver.
    And unfortunately that first UNINSTALL step deletes all of the Realtek Registry keys, which unfortunately deletes all the EQ setups since it is in the Registry that the SAVE process for an EQ setup gets stored. Too bad they don't put it in \ProgramData or \Users where it obviously belongs and could be preserved.
    So be sure you write down how many +/- ticks you push each slider up or down for each EQ setup, since you're going to have to reproduce and save each one all over again whenever you do decide to upgrade your driver version.
  4. Posts : 6
    It Worked thank you :)
  5. Posts : 14,606
    WOW! 10 weeks to solve that one.
  6. Posts : 1
    Windows 7 64bit
    Hey! I have the same problem, with saved presets! I set it up, save it while listening to music. When I restart the Win Media Player, I get default sound, when I tweak a bit the EQ setup it goes back to the saved preset, but if I restart WMP it gets resetted again. I updated to latest version, I have no idea, it didn't use to do this, it started to happen after I bought a new headset (same as previous, just it was broken), I have no idea.
