Windows 7: Help seting up Audio through HDMI to HDTV
20 Sep 2012   #1
Windows 7 Pro X64
My system specs are listed for my rig before I say anything that is what I am running ATM
Current video card has an HDMI and with space limitations been trying to get my 40" Toshiba to work as a monitor. I been trying to get audio to the set and found the options in the Gforce control panel, but it goes on to ask for the device in windows to be switch and windows dose not have a listing for such a device.
So I am not sure how to finish this up and use the TV as I wish. So is it possible to do so and if so I could really use the help.
20 Sep 2012   #2
Windows 7 Home Premium 64 bit. SP-1
Northern Ohio
Go to the Start Orb and type in Audio and then select Manage Audio Devices. Right click HD or HDMI as default. Right click again and select Test. If it works you will hear the test.
21 Sep 2012   #3
Windows 7 Pro X64
Quote   Quote: Originally Posted by Layback Bear View Post
It is not listed as an option when I checked before and then now it still was not.
21 Sep 2012   #4
Windows 7, 64 bit Home SP1, Win 8 Pro 64 bit
Citrus Co, FL
According to what I see, your video card has built in HDMI audio. First thing is to verify you have the correct video card driver, use the ASUS supplied driver to start with (other NVIDIA drivers should work but use the ASUS supplied initially). Go to the Control Panel/Hardware and Sound and finally the SOUND Panel/Playback section. The HDMI should be listed as one of the playback options and if an HDMI cable is plugged in, many will automatically switch to HDMI as the default playback device. If its not set as default playback device with a cable connected, set it as default. If you still do not get HDMI audio, there may be a hardware problem with the card.
21 Sep 2012   #5
Northern Ohio
The only thing I can think of is you don't have the proper cable plugged into the proper place. Double check you video card instructions.
21 Sep 2012   #6
Win 7 Ultimate x64
Etobicoke, Ontario
Actually it doesn't. What it has (and all Nvidia 8xxx/9xxx series with a HDMI port) is audio passthrough. It doesn't have built in audio like the AMD HD series and the newer Nvidia cards. To get sound over HDMI from that card you have to connect it to the SPDIF header on the motherboard or sound card,
Guide: 8800GT/9800GT/9800GTX Sound over HDMI (Now including Creative cards)
21 Sep 2012   #7
Windows 7 Pro X64
Quote   Quote: Originally Posted by stormy13 View Post
So where can I get that wire I will need? I don't have anything extra to cut even if I was willing to cut stuff from in the case.
21 Sep 2012   #8
Northern Ohio
My understanding your card should of come with it.
Packaging
Package ContentsEN9800GT HB/HTDI/512M
Driver Disk
User's Manual
HDTV Cable
Power Cable
DVI to VGA/D-sub Adapter
DVI to HDMI Adapter
S/PDIF Cable
http://www.newegg.com/Product/Produc...82E16814121268
21 Sep 2012   #9
Citrus Co, FL
As this is an old, discontinued, video card, that gets HDMI via an adapter, along with the needed S/PDIF connection to the PC's motherboard (if the motherboard even has an S/PDIF connector) is would probably be better to upgrade to a new video card that does have built in audio and HDMI.
21 Sep 2012   #10
Windows 7 Pro X64
That would require more money then I could afford at the moment.
As for the cable if it did come with the box, then I can only say it is in storage and not something I can find or pull out easily. i just recently moved and don't have all my stuff out or know where it would be.
 Help seting up Audio through HDMI to HDTV problems?
Similar help and support threads for: Help seting up Audio through HDMI to HDTV
HDMI - HDMI gettting fuzzy display on HDTV. Graphic Cards
hdmi hdtv Graphic Cards
HP Laptop Via HDMI to HDTV Media Center
Win7 + HD 4350 + HDMI + Audio + HDTV good plan? Graphic Cards
Laptop > HDTV (HDMI - HDMI) No Audio!? Sound & Audio
