"Stereo Mix" to record sound from card missing.
freshmeat20
9:23 PM
Im trying to playback audio for sstv through my sound card and the "Stereo Mix" option is missing as an audio input (recording) method. I have some in-product sound card that came from Dell so I've been told it may not be possible. But I've found free software that does record in the same exact way that "Stereo Mix" would. Is there any universal sound drivers out there that would add "Stereo Mix" as an option?
Windows 7 Ultimate 64-bitIntel duo 2.2 ghz3gb RAMNvidia 9400m
Dell Studio 1440
Intel duo 2.2 ghz
3gb RAM
Nvidia 9400m
Realtek
320GB
150gb- Ubuntu sda4 /
150gb-Windows 7 sda3
If you have Dell you may be stuck with what it will do. Dell's, in most cases, require Dell specific sound drivers as non-Dell either does not work (won't install in many cases) or does not work correctly. I used to do a lot of support on the Dell forums and that was a major complaint with certain model Dell's.
If you have a software solution that gets around the lack of System Mixer that is the best you can do.
My Own Build
Intel i7 6700K
ASUS ROG Maximus VIII Hero
16GB Corsair Dominator
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
2 TB drive for backup
EVGA Supernova 750G2
BeQuiet Silent Base 600
Deepcool Captain 120EX
Microsoft Wireless 2000
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
