PC to TV no sound
  1. Posts : 3
    windows 7
    PC to TV no sound
    Hi we have Dell N5030 with Realtek 6.0.1.6136 sound card, having read some earlier threads I have tried everything suggested including ticking show disabled devices but only get Loudspeaker as a device.
    All and any help will be much appreciated
    GM
  2. Posts : 31
    win7
    Hi Rodbourne16,
    How exactly are you connecting TV to the computer?
  3. Posts : 8,135
    The Dell manual does not show and HDMI port for this model.
    I assume you are connecting via VGA for the video and from the headphone jack to the TV for Audio (?). That means you have to be able to enable both of those on the TV.
  4. Posts : 278
    MS Windows 7 Home Premium 64-bit SP1
    EDIT: nevermind, I was wrong
  5. Posts : 3
    windows 7
    Update
    Sorry found out the Dell does not have an HDMI so problem now is can I fit one to the Dell or must I use VGA and Audio cable ??
  6. Posts : 8,135
    I've seen adapters that will convert VGA and Analog Audio out to HDMI. I don't know if they are available for TV standards other than US TV standards (or whether that matters).
    Here is one listed on the US Amazon site: Amazon.com: VGA and Audio to HDMI Converter: Electronics
  7. Posts : 3
    windows 7
    Thanks for the info they are available here so will give it a try
  8. Posts : 5
    Windows 7 Home
    i think you cannot do it
    and i never see as before!
    Sony Tv Live Streaming
    aag tv live
    i am sorry if i heat you
