Windows 7: Sound Error: no audio devices are installed - hp pavillion dv6500
27 Sep 2012   #1
windows 7
hi all, im new to this site. I have problem with my sound. There were no problems before but now whenever i try to put the volume higher an error alert saying no audio devices are installed comes on. i have looked around and tried going to services.msc but it didnt work. I really cannot stand having no sound!
thank you all.
ss0900
Sound Error: no audio devices are installed - hp pavillion dv6500-audio.png
27 Sep 2012   #2
Windows 7, 64 bit Home SP1, Win 8 Pro 64 bit
Citrus Co, FL
What did you do to cause the problem, if you know? Did you do a complete reinstall? Have you disabled the audio in the BIOS? Did you run a "Registry Repair" program?, etc.
28 Sep 2012   #3
windows 7
fireberd
thanks for replying. I turned the laptop on and off and the sound went with it. Thanks
28 Sep 2012   #4
Citrus Co, FL
Ouch. Try a System Restore and see if that brings it back, as a first step. System Restore can be accessed from Start/Programs/Accessories/System Tools. Select a restore date that is prior to whatever happend. System Restore will not delete any user data or e-mails, but if something was installed or updated you will have to do that again.
 Sound Error: no audio devices are installed - hp pavillion dv6500 problems?
Similar help and support threads for: Sound Error: no audio devices are installed - hp pavillion dv6500
No Audio Devices Installed, Help !~! Sound & Audio
Solved No audio devices are installed Sound & Audio
No Audio Devices Are Installed in Recording Tab Sound & Audio
No audio devices are installed. Please help. Sound & Audio
No audio devices are installed. Sound & Audio
