Windows 7: Front audio jack issue, F_Audio port query
28 Sep 2012   #1
SeVeNrOxS
Windows 7 RTM x86
Hello
Since I purchased PC few years back, my front audio jack was not working. Today I decided to fix the issue instead of purchasing a new headphone (I'll use mobile headset :P ).
I'm using Windows 7, my motherboard name is Gigabyte GA MA78gm S2H. When I saw a video in youtube and read mb's matual, I found that there is something called F_Audio. I checked my MB, there was nothing plugged in that port.
I've four wires coming out from front side i.e HDD led, power led, reset and Speaker. I've connected those wire properly. Which wire should I connect to f_audio ? There is no wire left to connect I think the front jack is not working due to the missing cable. My rear audio jack is working properly.
Please help
Thank you
28 Sep 2012   #2
fireberd
You should have a cable (or cables) coming from the front panel for audio. One connector will be marked HD Audio (what is needed for current audio systems) and the other is AC97 which is for older audio systems.
Check around, if you don't see them as they may be stuffed somewhere in the front of the case.
29 Sep 2012   #3
SeVeNrOxS
Windows 7 RTM x86
No other cable is coming from front panel.
I'll open the front panel and check, will report back.
29 Sep 2012   #4
SeVeNrOxS
Windows 7 RTM x86
I opened the front panel of cabinet, I found that there were two cables (3.5 mm jack) coming out, one had "mic' and other had "Aux" written on it. Plugged the mic and aux in rear jack's mic and speaker respectively. Now audio from front panel is working
Thanks fireberd
29 Sep 2012   #5
fireberd
Great!. Have fun. Thanks for the feedback that you got it working.
Front Audio Jack, right sided speakers/cup not working
Hello, I'm Artekis. A year ago, sevenforums helped solved my BSOD problem! Now I'm back for help on audio problems. I recently noticed that the front audio ports of my Windows 7 PC do not work properly. I plugged in both speakers and my headset, and the right side of the speakers do not work as...
Front jack not working for Realtek HD Audio on Windows 7
Hi all, I've just installed Windows 7 and was very happy to see all the hardware working, even my Realtek HD Audio sound card, except the front jacks. On windows XP I could solve this by with the Sound Manager that comes with the realtek drivers, and select the "Disable front panel jack...
Front I/O Audio Jack not working.
Hello, Last month I built my own computer. I am having a problem with my Front I/O audio jacks. - Headset is Beats by Dr. Dre Solo HD - I have went into BIOS and enabled my Front I/O - My front I/O is properly connected to my Motherboard - My driver is Realtek HD R267 (Newest driver)
Front audio headphone jack reversed stereo...
I have a Gigabyte GA-P55-UD5 motherboard with on-board sound by Realtek, and my case is Thermaltake's "Element G". I connected the front panel audio cable to the designated connection on the motherboard, however, whenever I plug-in my headphones, the stereo is reversed! Meaning that the...
static from front audio jack??????
i have a acer ax1700-u3700 desktop computer. the front audio jack makes a static audio noise when moving the mouse. but when im not moving it it doesnt make noise. its worse when i click the start button and look threw the stuff on the menu. all drivers are current. upgraded bios to lastest at...
can't set front jack as default audio output (notebook)
Hi !'ve got a probelm with my compaq 615 i had a problem with my audio quitting on me after the laptop went to sleep (which required a reboot) so i reinstalled the drivers (IDT HD) now my laptop speakers are set as the default audio device and my headphone jack is set as the default...
