my sound driver keeps disappearing
  1. Posts : 7
    windows 7 64bit home
    So Lately I been getting this problem where I put my computer to sleep and then turn it back on it loses its sound, its saying there is no driver installed, I have to reboot the system and then go to the bios to turn off the integrated sound and then turn it back on and sometimes after it doesn't even pick it up . Any ideas ?
    Also when I turn it on the driver isn't even red or yellow in the device manager.
    Audio driver : SigmaTel High Definition Audio CODEC(for 64-bit windows)
    Computer: Dell XPS 420 Windows 7 64bit
    Boris
    First issue, are you using the Dell supplied SigmaTel driver? If not, that could be the problem. I used to do a lot of support on the Dell forum and we found non-Dell sound drivers either do not work or do not work correctly.
    Dell has a Vista driver and that should work OK on Windows 7 (Dell does not officially support Win 7 on this model).
    Drivers and Downloads | Dell [United States]
    Download and install the Dell driver and see if that helps.
  3. Posts : 264
    Windows 7 Enterprise x64
    Hi Boris,
    As very well mentioned by “firebird”, am sure you must have tried that option and it should have fixed the issue. If the issue still persists and if this issue started occurring after doing some recent software changes on your computer, then I would suggest you to try restoring your system back to a date when it was working fine. System Restore will affect Windows system files, programs, and registry settings only.
    For System Restore steps, you can refer to the URL mentioned: http://windows.microsoft.com/en-US/windows7/products/features/system-restore
  4. Posts : 21,004
    Hiyya could try Control Panel / Device manager / left click Sound / right click the device try the update option on line see what it comes up as.:)
