Windows 7 X-Fi Fatality Pro W7 x64, losing sound after restart windows
  1. Posts : 4
    hello I have a problem which does not happen often,the XF's are lost after rebooting Windows and it does not happen every time, ie occur alternately eg after 2 and sometimes 10 days...then i go to device manager sound and i have sb x-fi but at sound i havnt sound icon so i click right at sb x-fi icon at dm and uninstall...reboot windows..after rebooting sond install by itself.....my sound card from motherboard is disabled at bios..
    my pc : all latest drivers for all components nothing overclocked
    OS:
    Win 7 ultimate x64 sp1
    Processor:
    Intel Core™ i5-2500K Processor
    Motherboard:
    MB Asrock Fatal1ty P67 Professional B3
    Memory:
    Corsair 8GB, 2x4GB, DDR3 cl8
    Hard Drive:
    SSD OCZ agility 3 60GB
    Seagate 1,5 TB
    Samsung F3 1TB
    Transcend 250GB SATA, 2,5
    DVD :
    Pioneer bd rom bdc 202
    Video Card:
    Gainward Geforce GTX 680
    Sound card:
    X-FI Xtreme Gamer Fatal1ty Pro
    Power:
    Corsair TX 750w v2
    Since you have a separate sound card, do you have the Integrated (on the motherboard) audio disbled in the BIOS? If not, that can conflict with the sound card.
    (I have a PC that I recently built using an ASRock Z77 Professional (Fatal1ty) motherboard. It's a "utility" PC and not my prime recording studio PC but works well. It has an i5 3550 CPU).
  3. Posts : 4
    i wrote "my sound card from motherboard is disabled at bios" this problem happen almost a year when i buy this pc..graphic card i change later
  4. Posts : 8,135
    Do you have the latest Creative Xfi drivers? that would be the next step. As I mentioned originally drivers are usually the cause of these types of problems.
    I assume this is your sound card and here is the driver downloads. The driver is relatively old (2010) so it may be the one you have. If it is the same, reinstall it anyway over the existing drivers. Usually, Creative issues more driver updates but for this model its just the older driver. Creative Worldwide Support > Sound Blaster X-Fi Titanium Fatal1ty Professional Series
  5. Posts : 4
    hy i have all latest updates btw my card is Creative Worldwide Support
    Support > Select Your Product > X-Fi XtremeGamer Fatal1ty Pro Series > Download
    not titanium
    strange is it happening alternately not every day wtf
  6. Posts : 8,135
    The link I posted has the identical driver as the link you posted. That is common with Creative, the driver can cover many different models.
    I wonder if its some other device or something in Windows startup that is randomly causing the problem? The sound is on a shared Interrupt (IRQ) with another device. The other device is higher priority and thus can interrupt the sound. That is another area to look at, and see what the other device is.
  7. Posts : 4
    for now uninsall drivers and install new register my product will see now if happen,but i do that before and same problem maybe i m lucky :)
    my start up:
    edit:
    CTxfihlp unknow CTXFIHLP.EXE is my sb x-fi,i notice wtf at irq 16 sb x-fi and irq 17 high definition audio controler is Nvidia from graphic card
  8. Posts : 6,879
    Win 7 Ultimate x64
    Sound dissapears on sytem startup (SSD related)
    My Xtreme Music started doing the same thing about a month ago. Easiest solution I have seen so far without going back to onboard (sucks) or getting a new card, is to go into Device Manager and uninstall it from there and then scan for hardware changes to "re-install" the driver (also no restart required this way).
