Windows 7: SRS control panel on HP laptop altering sound
21 Oct 2012   #1
monores
I have an HP ProBook 4730s, which comes with "SRS premium sound" sound card. It has it's own "SRS audio settings" control panel, which actually sells you rocks as candy (i.e. fancy interface with really strange and useless options for a sound card).
I just discovered that my headphones have NO BASS, approx. everything under 150Hz is at 50% it's original volume.. A quick search on the 'net says to "disable system effects" (Playback devices > Speakers device > properties > effects tab > check "disable system effects"). It solves the problem!
Please notice that the tab is named "Effects" and NOT "Enhancements". Other playback devices have "Enhancements" tab instead.
But I want to FIND where these system effects are and disable only the ones which kill my bass. The "effects" panel shows no effects.
So I'm guessing that the "SRS premium sound" software is destroying my sound. And believe me, the sound is REALLY bad. Or are there any other effects, somwehere else and I'm missing it?
Is it safe to uninstall the SRS control panel?
Thanks guys!
22 Oct 2012   #2
fireberd
The SRS isn't actually your "sound card", its just a software add on to the "sound card". And the "sound card" is actually a hardware chip on the motherboard.
There are sound "enhancements" (effects) such as reverb, echo, chorous, etc available but they should not be affecting frequency response. Are you sure its the PC and not the headset? Have you tried the headset on a different PC or tried a different headset?
If you've installed some other sound driver that can be an issue as the PC vendor (HP in this case) sound driver is the best one. Non vendor sound drivers can either not work or not work correctly.
22 Oct 2012   #3
nagual
Go to Start/Run/Msconfig/Startup, and untick "SRS...", Apply/OK, and you are donne.
(Here, only antivirus is enabled in Startup)
Sound Control panel takes 2 minutes to open; HDMI sound inconsistent
Brand new Windows 7 Home Premium (6 bit) computer. When I click on the Sound control panel item, sometimes it takes 1-2 minutes to open. But that's kind of minor (although I'd like to know how to fix it), because sometimes the HDMI sound to my HDTV works fine, and sometimes it doesn't work at all....
Editing the sound in Control panel
If you go to control panel/Sound & Sounds, I noticed that there are some programs there that I once had installed. Is there a way to remove/edit those old programs so that they no longer are listed? Tx
Sound control panel configuration
I just got new 5.1 surround sound speakers and i have a couple of problems configuring them properly. 1. with higher frequency there's a static noise, which i believe has to do with treble, in the control panel the sound configuration doesnt offer any option to change this, any tool which i...
Can't open sound control panel
This is a fun one. The sound CP functioned. I added USB headset--still functioned. I installed drivers for my X-Plosion--still functioned. Rebooted--no longer functioned. At this point I cannot access the sound CP, nor the playback/recording devices screens, though the devices all function...
dont know what when wrong but I cannot access my audio devices control panel. Control Panel...Hardware and Sound..Manage Audio Devices. Nothing happens. Only a brief flicker. I also cannot change system sounds. Any idea what could be the problem? or at least how to go about debugging it.
