Tool to maintain uniform sound volume in W7?
Wiedman
7:13 AM
G'day you all fine people :D
As per the title: does something like that exist? I've googled and googled, but I can't find anything. The problem is of course this; W7 sounds are in volume 10, then Youtube is suddenly louder, say volume = 15, then Foobar = 16 in track one, and 11 in track 2, and so on and so forth. A tool that normalizes sound everywhere (no matter which source, say volume = 12) is what I would be looking for, because I am constantly changing the sound volume, and this is not exactly automation - which is what we have computers for :party:
Thank you in advance for any suggestions; much appreciated :-)
Bye,
W7-64I5 - 3570K16GBIntegrated
W7-64
I5 - 3570K
Gigabyte
16GB
IIyama 24"
1920 x 1200
SSD 128 GB
Corsair
Yes
HP
Don't know, but too slow :-)
There may be software that can perform this role for you but there is nothing native to Windows on offer, as this is typically a function that concerns the sound redistribution device.
When I used to run on a 5.1 HDMI-based uncompressed PCM system I would very rarely run in to this kind of situation where I often found myself changing the volume at the amplifier. Because this is an issue of quality and sensitivity on the speakers and the amplification, it was all a matter of being more agile with my volume adjustment, knowing when to go up or down where appropriate.
I suggest running all of your source audio at highest quality and volume levels, and adjusting the gain actively on the end device, or if you're running a standard desktop speaker system then you're out of luck as there may or may not be any custom software written to combat this.
Consider looking in to your audio driver control panel(s) for any relevant settings.
In addition to this, if you have any custom amplification, compressor-based or equalizing setting active, then you may want to turn that stuff off just to see where the differences are really coming from.
There is no simple solution, unfortunately. Especially when you're noticing differences between audio in the same piece of software (Foobar). It is likely your speaker sensitivity.
Windows 8 Pro x64i7 3820 @ 4.68GHzF3-12800CL9D-8GBXL (32GB)GTX 480 SLI
Windows 8 Pro x64
i7 3820 @ 4.68GHz
ASUS Rampage IV Extreme RoG BF3
GTX 480 SLI
Auzentech X-Fi HomeTheater HD
Sony 32V5500
LSI MR9260-4i (RAID10):
Toshiba DT01ACA300 x 4
iaStorA:
OCZ Vertex Enterprise 120GB
ST3500320AS 500GB
Intel 520 Series 120GB
OCZ ZX 1250W
HAF X
H80
Cyborg V.7
Razer Lachesis 3.5G 5600dpi
23296kbps ds / 812kbps us ADSL2+
Mozilla/5.0 (Windows NT 6.3; Win64; x64; rv:32.0) Gecko/2010
AverMedia C127 Game Broadcaster HD
