No sound - Windows only showing front jack and not rear jack
  1. Posts : 3
    Windows 7 Professional x64
    Hi everyone,
    I recently reinstalled Windows 7 pro on my PC. Sound was working fine before. Now Windows only shows a front jack in the sound playback device settings. There is no front jack, however, only a rear jack and it is not working. If I play music the levels monitor shows sound playing, but nothing comes out the rear 3.5mm headphones jack. Drivers all claim to be correct and up to date. I tried disabling the "Audio legacy front panel" in BIOS, and left audio set to enabled, to no avail. I attach a screenshot. Any suggestions?
    Many thanks for any ideas!
    Attached Thumbnails Attached Thumbnails No sound - Windows only showing front jack and not rear jack-sound-issues.jpg
  2. Posts : 6,879
    Win 7 Ultimate x64
    bobsy welcome to the Seven Forums.
    You need to install the driver for your sound, as it is currently running on the default Windows audio driver. Can;t tell you what it is you need as you didn't include the make and model of either the computer or motherboard.
  3. Posts : 3
    Hi stormy13, many thanks for your reply. My PC was custom built and so doesn't have a make. It has an Intel Desktop Board. I can't find a model number written on it, unfortunately. Anyway - Intel has a driver update utility so I will try that and let you know how it goes. My Ethernet connection (also on-board) is also showing up as not working properly in Device Manager. I don't use it so it wasn't bothering me and I hadn't made the connection until now...
  4. Posts : 3
    And... bingo! Two problems solved in one go. A whole bunch of drivers needed updating. Moral of the story: Just because Windows says the drivers are up to date, it doesn't mean they are. Many thanks stormy13 for your help. By the way, it turns out I have a DQ57TM board.
  5. Posts : 6,879
    Win 7 Ultimate x64
    You're welcome.
    With now knowing what motherboard you have you can also get the audio drivers from here,
    Latest Realtek HD Audio Driver Version
    Maybe evern bookmark this link,
    http://downloadcenter.intel.com/Sear...p+Board+DQ57TM
    if you ever re-install Windows again as well.
