Windows 7: Why is the SRS Sandbox (or any other SRS program) Not showing in Sound
27 Oct 2012   #1
Windows 7 Home Premium 64Bit
Hey I've Downloaded and Installed SRS Audio Sandbox, (previously Audio Essentials, and SRS HD Audiolab Gold) and SRS does not show up in the control panel>Sound>playback. I've Installed SRS HD Audiolab Gold,Essentials, and sandbox. Each time SRS is not shown in the Control Panel. What is going on? I should also point out that Audiolab gold had worked great for a while, but it kept saying it had an internal resource error and to install the program again. That worked a couple of time but now. It Installs but when I go to enable SRS in Sound, It is not shown there at all. Is there anybody else with this problem? If so, Any fixes? Thanks in Advance.
Similar help and support threads for2: Why is the SRS Sandbox (or any other SRS program) Not showing in Sound
Solved C:/Program and C:/Program(86) - Not Showing Software
No sound from speakers but showing sound graph on speaker control Sound & Audio
need a sandbox program Software
Sandbox program for 64 bit? Software
Program files (x86) not showing ! General Discussion
SRS Sandbox sound issues, no voice... Sound & Audio
Program windows not showing up General Discussion
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33
