Windows will not recognise microphone input from external sound device
I'm running Windows 7 Home N SP1 x64. I'm using an M-Audio Fast-Track Pro device to record audio into a music sequencer (Cubase 5), through a Shure SM58 Microphone. The M-Audio box is connected to the computer via USB. I've been using this set-up for about a year now and it hadn't caused me any problems until the last few weeks. For some reason Windows is not registering any signal from the input of the M-Audio box. The box itself picks up the sound and I can hear tapping on the microphone when M-Audio is selected as the output device, but not from the built-in speakers.
I first noticed the problem in the software (and thought for the longest time that it was the software). I'm very competent with Cubase and tried everything I could think of to get it to register with no avail. It was only when I tried to use the device on another sequencer that I realised that it's not the software. Then, since the mic works fine, the box itself is picking up the signal and out-putting it through itself, it must be something wrong with the computer or the OS.
I've re-installed the M-Audio driver, didn't make any difference. I've set the M-Audio as default in both playback and recording tabs in the sound control panel. Playback works fine. One thing that's really strange is that when I open manage sound drivers in the control panel and tap on the mic, neither the levels in recording nor playback even flutter, even though I can hear it pretty clearly through the headphones.
I'm out of ideas, any help would be appreciated! Cheers!
