| Windows 7: Does anyone have advice for using an external sound card? |
01 Nov 2012
#11 | | Windows 7 Home Premium 64-bit |
Quote: Originally Posted by fireberd Do you have any "Sound Enhancements" enabled. My RealTek and many others have some options for enhancements such as echo, reverb, chorus.
"Recorded music" is bad. What happens if you play a commercial audio CD? Or some other audio from the internet?
Also, what program are you using to record, and what are you recording? There are no sound enhancements that I am aware of. If I just listen to music it sounds perfect. When I try recording on this Toshiba Satellite with the "sound recorder" or another program like Roxio it gets garbled. That same Roxio program on my old computer recorded beautifully. I am recording music from either Youtube or my Zoom recorder I use to record live music. Played through my stereo that Zoom sounds perfect. When I record it on my computer it gets garbled. | My System Specs |
| System Manufacturer/Model Number Toshiba Satellite L745-S4210 OS Windows 7 Home Premium 64-bit CPU Intel Core i3 2310M @ 2.10 GHz Sandy Bridge 32nm technology Motherboard Intel Corp. Base Board Product Name (CPU1) Memory 4.00 GB Graphics Card Generic PnP Monitor 1366 x 768 @ 60 Hz Intel HD Graphics Sound Card Conexant SmartAudio HD |
01 Nov 2012
#12 | | Windows 7, 64 bit Home SP1, Win 8 Pro 64 bit Citrus Co, FL |
OK. So its just recorded music that is bad.
In the Sound Panel, Recording section. You should have Stereo Mix or System Mixer (both are the same). Doubleclick on that and it will bring up the Stereo Mix (or whatever yours is called) panel. In mine there is an enhancements tab (section) that enhancements can be enabled or disabled. Check yours to see if there is something there. | My System Specs | | Computer type PC/Desktop System Manufacturer/Model Number My Own Build OS Windows 7, 64 bit Home SP1, Win 8 Pro 64 bit CPU Intel i7 3770 Motherboard Gigabyte GA-Z77X-UD5H Memory 16GB GSkill Ripsaw F3-14900CL9Q-16GBXL Graphics Card Sapphire HD7770 Sound Card RealTek Monitor(s) Displays Viewsonic VA2448 Series 24" LED Screen Resolution 1920X1080 Keyboard Kensington wired Mouse Logitech Wireless PSU Antec High Current Gamer HCG-620M Modular Case Coolermaster HAF XM Cooling Corsair H80 Liquid cooling with aftermarket Nexus quiet fans Hard Drives 240GB Intel 520 SSD for Win 7
128GB OCZ Vertex 4 SSD for Win 8
1 TB Seagate drive for backup Internet Speed 40 MB/sec (Cable) Antivirus Microsoft Security Essentials and Malwarebytes Browser I.E9/Firefox Other Info Sonar X2 Professional 64 bit Recording Software with Roland Octa-Capture and MAudio Fast Track Ultra 8R recording interfaces, Frontier Tranzport wireless control unit, Behringer BCF2000 Control Surface.
Five USB connected optical drives for CD Audio production using Nero 11
Other systems: Desktop with i5 3550 CPU, LenovoZ560 Laptop with Win 7 64 bit HP, SP1, new iPad |
01 Nov 2012
#13 | | Windows 7 Home Premium 64-bit |
Quote: Originally Posted by fireberd OK. So its just recorded music that is bad.
There is only a Stereo Mixer on the Playback. There is no Stereo Mixer on the Recording Section. The only thing I get when I click on the microphone in that section is a way to configure the speech recognition stuff. I did click on properties and see that there is a Microphone Boost in that section. I turned down the microphone boost from 24 dB to 12 dB. | My System Specs | | System Manufacturer/Model Number Toshiba Satellite L745-S4210 OS Windows 7 Home Premium 64-bit CPU Intel Core i3 2310M @ 2.10 GHz Sandy Bridge 32nm technology Motherboard Intel Corp. Base Board Product Name (CPU1) Memory 4.00 GB Graphics Card Generic PnP Monitor 1366 x 768 @ 60 Hz Intel HD Graphics Sound Card Conexant SmartAudio HD |
01 Nov 2012
#14 | | Windows 7 Home Premium 64-bit |
I tried recording again with the Microphone boost down and this time it came out crystal clear for 25 seconds, then sounded underwater/garbled again. | My System Specs | | System Manufacturer/Model Number Toshiba Satellite L745-S4210 OS Windows 7 Home Premium 64-bit CPU Intel Core i3 2310M @ 2.10 GHz Sandy Bridge 32nm technology Motherboard Intel Corp. Base Board Product Name (CPU1) Memory 4.00 GB Graphics Card Generic PnP Monitor 1366 x 768 @ 60 Hz Intel HD Graphics Sound Card Conexant SmartAudio HD |
01 Nov 2012
#15 | | Windows 7, 64 bit Home SP1, Win 8 Pro 64 bit Citrus Co, FL |
There should not be a Stereo Mixer on the Playback. If there is there is a major problem. The Default Playback device should be set to your "Speakers" (the Connexant integrated audio device). However, you should have Stereo Mixer in the Recording section. Bring up the Sound panel/Recording section and then RIGHT click in an empty space in the panel and then check the boxes to show disabled devices and disabled devices. If the Stero Mixer is now shown, enable it and make it the default recording device. | My System Specs | | Computer type PC/Desktop System Manufacturer/Model Number My Own Build OS Windows 7, 64 bit Home SP1, Win 8 Pro 64 bit CPU Intel i7 3770 Motherboard Gigabyte GA-Z77X-UD5H Memory 16GB GSkill Ripsaw F3-14900CL9Q-16GBXL Graphics Card Sapphire HD7770 Sound Card RealTek Monitor(s) Displays Viewsonic VA2448 Series 24" LED Screen Resolution 1920X1080 Keyboard Kensington wired Mouse Logitech Wireless PSU Antec High Current Gamer HCG-620M Modular Case Coolermaster HAF XM Cooling Corsair H80 Liquid cooling with aftermarket Nexus quiet fans Hard Drives 240GB Intel 520 SSD for Win 7
01 Nov 2012
#16 | | Windows 7 Home Premium 64-bit |
Quote: Originally Posted by fireberd There should not be a Stereo Mixer on the Playback. If there is there is a major problem. The Default Playback device should be set to your "Speakers" (the Connexant integrated audio device). However, you should have Stereo Mixer in the Recording section. Bring up the Sound panel/Recording section and then RIGHT click in an empty space in the panel and then check the boxes to show disabled devices and disabled devices. If the Stero Mixer is now shown, enable it and make it the default recording device.
I have it up now....the choices in recording section properties is General, which says it's working normally, Listen, which is set to "default playback device" with "speakers conexant smartaudio HD" as an alternative. It's set on "default playback device". Levels where the mic and boost are located and Advanced where I see there is an "audio enhancements" box that is checked. NO stereo options in the Recording section. | My System Specs | | System Manufacturer/Model Number Toshiba Satellite L745-S4210 OS Windows 7 Home Premium 64-bit CPU Intel Core i3 2310M @ 2.10 GHz Sandy Bridge 32nm technology Motherboard Intel Corp. Base Board Product Name (CPU1) Memory 4.00 GB Graphics Card Generic PnP Monitor 1366 x 768 @ 60 Hz Intel HD Graphics Sound Card Conexant SmartAudio HD |
01 Nov 2012
#17 | | Windows 7, 64 bit Home SP1, Win 8 Pro 64 bit Citrus Co, FL |
Here is what I have for the Playback and Recording panels. You should have something close to these. | My System Specs | | Computer type PC/Desktop System Manufacturer/Model Number My Own Build OS Windows 7, 64 bit Home SP1, Win 8 Pro 64 bit CPU Intel i7 3770 Motherboard Gigabyte GA-Z77X-UD5H Memory 16GB GSkill Ripsaw F3-14900CL9Q-16GBXL Graphics Card Sapphire HD7770 Sound Card RealTek Monitor(s) Displays Viewsonic VA2448 Series 24" LED Screen Resolution 1920X1080 Keyboard Kensington wired Mouse Logitech Wireless PSU Antec High Current Gamer HCG-620M Modular Case Coolermaster HAF XM Cooling Corsair H80 Liquid cooling with aftermarket Nexus quiet fans Hard Drives 240GB Intel 520 SSD for Win 7
02 Nov 2012
#18 | | Windows 7 Home Premium 64-bit |
Quote: Originally Posted by fireberd Here is what I have for the Playback and Recording panels. You should have something close to these.
All I have on mine are speakers and microphone. No realtek or stereo mix. | My System Specs | | System Manufacturer/Model Number Toshiba Satellite L745-S4210 OS Windows 7 Home Premium 64-bit CPU Intel Core i3 2310M @ 2.10 GHz Sandy Bridge 32nm technology Motherboard Intel Corp. Base Board Product Name (CPU1) Memory 4.00 GB Graphics Card Generic PnP Monitor 1366 x 768 @ 60 Hz Intel HD Graphics Sound Card Conexant SmartAudio HD |
02 Nov 2012
#19 | | Windows 7, 64 bit Home SP1, Win 8 Pro 64 bit Citrus Co, FL |
This appears to be the sound download for your model. Suggest you download and install it, even if its the same driver that you have.
Conexant driver 8.51.1.0a http://www.csd.toshiba.com/cgi-bin/t...ily=1073768663 | My System Specs | | Computer type PC/Desktop System Manufacturer/Model Number My Own Build OS Windows 7, 64 bit Home SP1, Win 8 Pro 64 bit CPU Intel i7 3770 Motherboard Gigabyte GA-Z77X-UD5H Memory 16GB GSkill Ripsaw F3-14900CL9Q-16GBXL Graphics Card Sapphire HD7770 Sound Card RealTek Monitor(s) Displays Viewsonic VA2448 Series 24" LED Screen Resolution 1920X1080 Keyboard Kensington wired Mouse Logitech Wireless PSU Antec High Current Gamer HCG-620M Modular Case Coolermaster HAF XM Cooling Corsair H80 Liquid cooling with aftermarket Nexus quiet fans Hard Drives 240GB Intel 520 SSD for Win 7
02 Nov 2012
#20 | | Microsoft Windows 7 Home Premium 64-bit 7600 cornwall UK |
Right click an area of the sound/record window and select show hidden or disabled items ,
I'm using my phone to post so I can't give you the exact terms ,but you should see similar when you right click, | My System Specs | | System Manufacturer/Model Number Hewlett packard/p6512uk OS Microsoft Windows 7 Home Premium 64-bit 7600 CPU IIx4 amd athelon 635 processor Motherboard FOXCONN 2AA9 Memory 2x2gb Graphics Card ati radeon HD 5450 Sound Card (1) Realtek High Definition Audio (2) AMD High Definition Monitor(s) Displays samsung lcd tv 32" Screen Resolution 1360x 768 Keyboard wireless hp Mouse wireless Hp,optical PSU ? Cooling air! Hard Drives (1) WDC WD10 01FAES-60Z2A0 SATA Disk Device (2) Maxtor OneTouch USB Device (3) ST310003 33AS USB Device (4) WD My Book 1111 USB Device Internet Speed 1.10mb/s Antivirus MSE Browser Firefox Does anyone have advice for using an external sound card? problems? All times are GMT -5. The time now is 06:29 AM. | |
