Windows 7: Does anyone have advice for using an external sound card?
02 Nov 2012   #21
Spritsailor
Windows 7 Home Premium 64-bit
This appears to be the sound download for your model. Suggest you download and install it, even if its the same driver that you have.
Conexant driver 8.51.1.0a
Model Content Page
I can download that even if I have a driver? BTW all I've seen so far going through the list that has an audio driver v8.54.44.0 8-14-2012; 51.72M.
02 Nov 2012   #22
fireberd
It looka like this one is the latest in the Win 7 64 bit (and 32 bit) listing.
Model Content Page
The 8.54.... version is listed for Win 8.
02 Nov 2012   #23
Spritsailor
Model Content Page
The only other sound driver in the list is nVidea HD Audio Driver v1.2.23.3;07-08-2011; 11.07M.
02 Nov 2012   #24
fireberd
I still recommend installing the latest version on the Toshiba download page for Win 7.
02 Nov 2012   #25
Spritsailor
Is it the one I mentioned? It's the only one on the list you linked me to.
02 Nov 2012   #26
fireberd
The latest version for Win 7. 8.51.2.51
Model Content Page
03 Nov 2012   #27
Spritsailor
Downloading it now! Thanks fireberd!
Do you play music in Nashville? I was just there in late August going to jam nights.
03 Nov 2012   #28
Spritsailor
Just tried recording with the new sound card upgrade and the garbling is still there after 30 seconds of playback.
03 Nov 2012   #29
fireberd
I'm out of suggestions. However, I still think its a problem in the PC and not the sound chip but something else causing it. You can try a USB connected external sound "card" as you originally considered but no guarantees that it will fix the problem.
I'm in Florida, not Nashville. I was there in the early 70's and had a day job as the Amplifier tech at a lower Broadway music store (across the street from Tootsie's that is no longer there). I was learning the pedal steel guitar back then but did play some jobs around Nashville including some of the lower Broadway clubs. The "R.O.P.E" is a fraternal organization of entertainers including singers, musicians and other industry personnel. I have a home recording studio here in Florida and have also worked Florida tours with some of the Nashville singers. I did 7 winter tours with Tommy Cash and two with George Hamilton IV, plus single shows with others including David Frizzell, Jack Greene, Bobby Bare, Ray Pillow and others. Tommy Cash was my sponsor to get into the R.O.P.E. organization.
07 Nov 2012   #30
Spritsailor
Fixed it! I found a box checked in the sound, recording, microphone, properites, advanced, "enable audio enhancements". I unchecked that "enable audio enhancements" box and the recorded sound is crystal clear.
Thanks for everyone's help!
Sound card advice
Hi, i have the Logitech Speaker System Z313 (was sent as replacement for my old one) but it does not have Bass controls on it, so i was wondering if i got a sound card could i control the bass through that ? Also If i got a sound card is there anyway i can control voices in movies ? i tend...
external sound card advice for use with monitor speakers
Hi Basically i've just got my new laptop this week, had desktop pc's for nearly 10 yrs with internal sound card to power a 5.1 surround system now ive ordered some krk rokik rp5 g2 monitor speakers but i want to be able to play music from laptop with media player etc, through the monitor...
Just looking for some sound card advice and suggestions
Hi, I just got a new computer, Intel I7 2600 processor, 8 gb ram, nvidea 550TI, MSIp67a-c43 motherboard and have 3 pcix1 express slots and 3 regular pci slots available. There are no PCI expressx16 slots available. Windows 7 home premium. I currently have an integrated sound on the motherboard,...
Need external sound card
I have an Alienware Area-51 7500-R4 with intergrated Nvidia C-55-MB. I recently installed Windows 7 (Custom, clean installation) and I only have sound on my two front speakers, no center or rear speakers. Alienware support is unable to help and I was told I could not install an internal soundcard...
Looking to buy a new external/usb sound card
Hello 7forums, My onboard soundcard isn't working with win7. I really like the performance win7 is giving me for everything, from games (no sound), to processor-heavy loads, but I just can't get the audio to work. I have tried a lot of sound drivers listed in these forums, but they all say the...
Sound Card Advice
I'm going from XP 32 bit to Win7 64 bit any advice on which sound card to buy (no vista 64 bit drivers for my old X-Fi Fidelity card)
