Solved Sound Don't Auto Turn Down?
ZMan
1:49 AM
In windows seven there is an tab called Communications that will auto turn down the volume by YZ% when you wan it to. Before I rewrote my Windows 7 system it turn down the music when I had an incoming call via Skype. Now after reinstalling my Windows 7 system even with the setting set correctly and label in the Playback and Recording listing as default communication device it still don't work not work anymore with Skype. All the posting that I come across are trying turn the feature off so it don't work. I can't find one with similar problems then me of it not working. Everything I can think of don't work so I thought I post up the issues here to see if anybody has a thoughts on how to get it to work again.
Any ideas?
windows 7 professional x32
Try setting the audio input device that you use with Skype as your default communications device in the recording sound control panel.
Windows 8 Pro x64i7 3820 @ 4.68GHzF3-12800CL9D-8GBXL (32GB)GTX 480 SLI
Windows 8 Pro x64
i7 3820 @ 4.68GHz
ASUS Rampage IV Extreme RoG BF3
GTX 480 SLI
Auzentech X-Fi HomeTheater HD
Sony 32V5500
LSI MR9260-4i (RAID10):
Toshiba DT01ACA300 x 4
iaStorA:
OCZ Vertex Enterprise 120GB
ST3500320AS 500GB
Intel 520 Series 120GB
OCZ ZX 1250W
HAF X
H80
Cyborg V.7
Razer Lachesis 3.5G 5600dpi
23296kbps ds / 812kbps us ADSL2+
Mozilla/5.0 (Windows NT 6.3; Win64; x64; rv:32.0) Gecko/2010
AverMedia C127 Game Broadcaster HD
T hat done it thanks LuzTeTT
Ah, good. Now I know how Windows handles that particular functionality of the volume thing.
Windows 8 Pro x64
i7 3820 @ 4.68GHz
GTX 480 SLI
Sony 32V5500
iaStorA:
ST3500320AS 500GB
OCZ ZX 1250W
HAF X
H80
Cyborg V.7
