Audio sound intrrupting while playing mp3 with headphones
asif143
8:13 AM
I’m facing this problem while playing the audio files(like mp3, wav...etc) with front panel headphones, the sound interrupting continuously (like 10 seconds sound-1 second mute-12 second sound-1 s mute-5 s sound-1 s mute) but there is no problem while playing video files. I opened the mixer from taskbar audio icon and saw the headphones device goes and comes cyclically while playing audio files. Please someone help me……
Windows 7 Ultimate x86Intel® Pentium® Processor G2010 2.80GHz-Ivy B...DDR3-4GBGalaxy Nvidia Geforce GTX 450
Custom build
Intel® Pentium® Processor G2010 2.80GHz-Ivy Bridge-Dual core
GIGABYTE B75M-D3H
DDR3-4GB
Monitor HCM7LWAT21 43cm (HCL)
320 GB
Cooler Master Thunder 450 Watts
3.1 mbps
Microsoft Security Essential
Firefox, IE 10.
Please fill in the "My System Specs" so we know what hardware you have.
Does the speakers do the same thing?
Have you tried a different headset?
Do you have the correct sound driver? The PC vendor (or motheboard in the case of a home/custom built system) sound drivers should be used. Non vendor drivers can be a problem in some systems.
My Own Build
Intel i7 6700K
ASUS ROG Maximus VIII Hero
16GB Corsair Dominator
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
2 TB drive for backup
EVGA Supernova 750G2
BeQuiet Silent Base 600
Deepcool Captain 120EX
Microsoft Wireless 2000
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
As you told i have filled "my system specs".
No, the speakers doesn't do the same thing.
Yes, i have tried different headset and faced the same problem.Not having the problem with same headset plugged in the rear panel while playing audio files.
I don't know whether i have correct sound driver.
Custom build
GIGABYTE B75M-D3H
DDR3-4GB
320 GB
3.1 mbps
Firefox, IE 10.
The same PC hardware and software (sound drivers) are used for both the audio from a video and the audio from a song file.
If you play a commercial audio CD do you get the same sound cut out? Is the audio cut out always with the same media player?
The Sound Card in the system specs would be your integrated (on the motherboard) sound such as RealTek, IDT, etc.
My Own Build
Intel i7 6700K
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
Yes, i get the same sound cut out from commercial audio CD.
No, I have tried different audio player (like WMP, AIMP3....e.t.c.) and with the same problem.
It is integrated Digital Audio (S/PDIF) (High Defination Audio Device).
Custom build
GIGABYTE B75M-D3H
DDR3-4GB
320 GB
3.1 mbps
Firefox, IE 10.
The "digital audio" is not used with analog outputs like headphones. Also, i you show the HD Audio Codec instead of what your actual sound module is then that is the first problem. The HD Audio Codec is a generic, basic function, audio driver installed by windows. You should have the correct vendor supplied sound driver as they usually work best.
My Own Build
Intel i7 6700K
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
