Sound problem
I have installed windows 7. Now I am facing problem with sound.
When I watch any video online there is no sound. Please help what to do
Hi Welcome to Seven Forums.
To help us help you would you please add your systems specs? Here's how: System Info - See Your System Specs
Under System Manufacturer/Model Number add whether it is a desktop or laptop and whether self built.
Log in to Seven Forums and you will be able to transfer the info directly to the specs page in your profile from within the System Info app.
After doing this your specs will be available in each of your posts. Click on My system Specs in the lower left of this post to see how it should look.:)
Full instructions are in the tutorial.
Did you reinstall your audio driver and enable it on BIOS?
I have done that & I did not reinstalled any audio driver
I can't find the PC's support page. You should install the latest Realtek driver, try Windows Update, it's in the Start Menu/All programs.
I tried installing the realtek driver. But in the end process of installation there was rtkvac.sys not found error. I have made a change in my system specs check it out. Also when I listen music on my desktop sound is there only if I use VLC
Let's try this, go to Control Panel\All Control Panel Items\Device Manager and click to open the Sound and Game controllers. For each item there double click it to open the properties window. Click uninstall (Advanced).
Reboot and drivers should install for you. do you have onboard audio enabled as I previously asked?
yes its onboard. That even didn't worked out
Reboot and press whatever key it syas to enter Setup or BIOS, F1, F2, DEL are common ones. Go to the hardware/Onboard devices section and fine Onboard Audio, make sure it says enabled.
