Windows 7: Sound problem
08 Nov 2012   #1
Ashish12
Windows 7 home basic 32-bit x86
Sound problem
I have installed windows 7. Now I am facing problem with sound.
When I watch any video online there is no sound. Please help what to do
08 Nov 2012   #2
Britton30
Microsoft MVP
Windows 7 Ultimate X64 SP1
Hi Welcome to Seven Forums.
To help us help you would you please add your systems specs? Here's how: System Info - See Your System Specs
Under System Manufacturer/Model Number add whether it is a desktop or laptop and whether self built.
Log in to Seven Forums and you will be able to transfer the info directly to the specs page in your profile from within the System Info app.
After doing this your specs will be available in each of your posts. Click on My system Specs in the lower left of this post to see how it should look.
Full instructions are in the tutorial.
Did you reinstall your audio driver and enable it on BIOS?
08 Nov 2012   #3
Ashish12
I have done that & I did not reinstalled any audio driver
08 Nov 2012   #4
Britton30
Microsoft MVP
I can't find the PC's support page. You should install the latest Realtek driver, try Windows Update, it's in the Start Menu/All programs.
08 Nov 2012   #5
Ashish12
I tried installing the realtek driver. But in the end process of installation there was rtkvac.sys not found error. I have made a change in my system specs check it out. Also when I listen music on my desktop sound is there only if I use VLC
08 Nov 2012   #6
Britton30
Microsoft MVP
Let's try this, go to Control Panel\All Control Panel Items\Device Manager and click to open the Sound and Game controllers. For each item there double click it to open the properties window. Click uninstall (Advanced).
Reboot and drivers should install for you. do you have onboard audio enabled as I previously asked?
08 Nov 2012   #7
Ashish12
yes its onboard. That even didn't worked out
08 Nov 2012   #8
Britton30
Microsoft MVP
Quote   Quote: Originally Posted by Ashish12 View Post
I know it's onboard, but is it ENabled in your BIOS?
08 Nov 2012   #9
Ashish12
How to check that
08 Nov 2012   #10
Britton30
Microsoft MVP
Reboot and press whatever key it syas to enter Setup or BIOS, F1, F2, DEL are common ones. Go to the hardware/Onboard devices section and fine Onboard Audio, make sure it says enabled.
 Sound problem
Custom Sound Scheme: Close Window Sound Plays Instead of Chosen Sound
Cheers all, Problem is as stated in the thread; I downloaded, untar'd and set the theme up today. I know it's specifically the "Close Window" sound since it's unique from the others. I'm referring to the following actions in particular (there may be more things I could do to proc it, but I...
Sound problem perrsists even after new sound card
As some of you might remember, a few weeks ago I had a problem with sound after I built a new PC and kept my old Win 7 installation using sysprep: http://www.sevenforums.com/sound-audio/280175-onboard-sound-issue-new-pc-build-2.html#post2308990. The problem was that the volume levels were off, and...
Sound problem
Hi all, I had this problem with my laptop sound randomly disappears and it comes back after a while like 15 min or so.I have Realtek HD Audio Driver installed.Is it problem with my driver? Can anyone help me with this? i am despreate !!!
Sound problem - need to 'scan for hardware changes' to get sound
Hi everybody I have a fairly strange problem with my Laptop. It came originally with Vista and a while ago I updated to Windows 7 32bit Home Premium. Since then I don't have any sound after booting the Laptop. By chance I found out that when I go into the device manager, right click on the sound...
Hardware & Devices
Windows Media Player Problem - Sound/skipping problem.
Oh look, another windows media player problem, lol. Well, it's something really weird, at first i thought it was just my computer being all slow or the file was messed up, No matter what movie or format i play it makes this weird screeching noise. It also lags pretty bad. I tried the scans, i did...
Music, Pictures & Video
sound problem
Hello, I have a sound problem on my HP Pavillon desktop (windows 7). Everytime, after some hours of use, I hear sound clicks&pops. I restart, and the problem is back after some hours. When sound clicks&pops occurs, I see abnormal CPU usage in task manager. Like going back and forth...
