Windows 7: How to enable sound when plugging/unplugging charger for laptop.
10 Nov 2012   #1
PCDC
Windows 7 Home Premium 32bit
I was wondering if anyone is familiar with a method to enable sounds for when you plug in or remove a charger connected to your laptop. It is not a problem with my pc, but is an option that is not available for me which i would like to install to let me know if i accidentally unplugged the charger, particularly if I'm working on a full-screen feature. Any help would be appreciated.
I have Windows 7 home Premium 32-bit installed.
10 Nov 2012   #2
fireberd
Windows 7/10 64 bit
In the System Sounds, there is an option for device connect or disconnect. This will probably do what you want. You will have to assign a sound for those functions.
The System Sounds panel can be accessed from Start/Control Panel/Hardware and Sounds. Click on "Change System Sounds".
10 Nov 2012   #3
PCDC
Didn't work but thanks for the suggestion. I don't think it is available in this version of windows... maybe it will be available in the next.
Headphones Plugging and Unplugging constantly bug
My problem is this, my motherboard is Biostar TP67B and I have downloaded the sound drivers from the manufacturer website which is realtek high definition audio.However, If i had left my headphone plugged into my front panel jack and when I restart my computer, the headphone icon keeps flickering...
Any way to auto switch power plans when plugging in to charger?
anyone know how to do this? when plugging in to AC adapter, the system switches to a different power plan?
Performance & Maintenance
Multiple BSODs after unplugging and plugging in flash drive.
Dual Core Windows 7 Pro 64 bit Toshiba laptop. My daughter was working on a Power Point project for school. She went to plug in her flash drive and it didnít seem to load the drive up. She unplugged it and then plugged it back in. We got a BSOD. We restarted it and it BSOD again. I tried some...
BSOD Help and Support
Plugging and Unplugging!
Getting ready to do the install on my new SSD with some trepidation. I have Raptors in Raid 0 right now and would like to simply unplug them, set the BIOS to AHCI and use the 0 port for the SSD experiment/potential fiasco. What I hope to be able to do if the SSD doesn't like me, is to unplug it,...
Hardware & Devices
How to enable unplugging of printer without 'safely removing hardware'
I would like to be able to unplug my printer without having to 'safely remove hardware' first. Currently, if I don't do this, the printer is liable to be renamed the next time that it's plugged in, meaning that I have to determine the current incarnation via 'Devices and Printers' and then select...
Hardware & Devices
