Weird startup and shutdown sound; I can't disable nor figure its cause
  1. Posts : 24
    win7 64 bit home premium
    Lately I have a weird startup and shutdown sound. I've never had Sounds turned on. I went to Control Panel/Sounds/Sounds and it indicated No Sounds scheme. Tried some of the sounds and they work. Changed scheme to Cityscape and tested. It worked. I rebooted. Changed scheme to No Sounds. rebooted. I still get weird Startup & Shutdown sound. Not that it's the worst thing in the world, but I have a suspicion it's the result of a virus. I've run MalwareBytes and SuperAntivirus and have Windows Defender updated and working.
    In the panel for System Sounds, did you uncheck the box for the Windows startup sound? Even if you have No Sounds you must still uncheck that box or you will get the startup (not sure about the closedown).
  3. Posts : 264
    Windows 7 Enterprise x64
    Please let us know if your hear this sound after signing in through your user account. If yes, then it could possibly be due to a virus infection. I would recommend you to test the symptoms while in safe mode with networking.
    You may try performing system restore if the issue started occurring recently.
    Please click Windows 7 System Restore | Dell for details.
  4. whs
    " Weird sound" is very generic. Can you describe it a bit - what does it resemble.
  5. Posts : 24
    yes, I did.
  6. Posts : 24
    sounds like someone humming. On startup it goes from low to high, on shutdown it is reversed.
  7. whs
    It must be the HDD reving up and down. If it really bothers you, replace the HDD with a SSD. That makes no sounds.
  8. Posts : 27
    Windows 7 Ultimate x86/x64 dual boot
    For me, all windows sounds are weird, that is why I always keep "no sounds" selected.
  9. Posts : 24
    I shut down; interestingly no sound accompanied shutdown, now.
    I started up and hit F8 repeatedly, but did not get into SAFE mode. I've rarely used SAFE mode and don't know for sure that F8 should work on this Sony Vaio laptop.
    The startup Sound played about the time I got to Desktop. Just checked and the Play Sound on Startup is NOT checked.
  10. Posts : 24
    vsrawat said:
    for me, all windows sounds are weird, that is why i always keep "no sounds" selected.
    ditto
