Weird startup and shutdown sound; I can't disable nor figure its cause
ChuckN
6:56 PM
Lately I have a weird startup and shutdown sound. I've never had Sounds turned on. I went to Control Panel/Sounds/Sounds and it indicated No Sounds scheme. Tried some of the sounds and they work. Changed scheme to Cityscape and tested. It worked. I rebooted. Changed scheme to No Sounds. rebooted. I still get weird Startup & Shutdown sound. Not that it's the worst thing in the world, but I have a suspicion it's the result of a virus. I've run MalwareBytes and SuperAntivirus and have Windows Defender updated and working.
win7 64 bit home premiumamd p340 dualcore3 gig
Sony Vaio VPCEE31FX
amd p340 dualcore
3 gig
laptop
In the panel for System Sounds, did you uncheck the box for the Windows startup sound? Even if you have No Sounds you must still uncheck that box or you will get the startup (not sure about the closedown).
My Own Build
Intel i7 6700K
ASUS ROG Maximus VIII Hero
16GB Corsair Dominator
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
2 TB drive for backup
EVGA Supernova 750G2
BeQuiet Silent Base 600
Deepcool Captain 120EX
Microsoft Wireless 2000
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
Please let us know if your hear this sound after signing in through your user account. If yes, then it could possibly be due to a virus infection. I would recommend you to test the symptoms while in safe mode with networking.
You may try performing system restore if the issue started occurring recently.
Please click Windows 7 System Restore | Dell for details.
Windows 7 Enterprise x64
" Weird sound" is very generic. Can you describe it a bit - what does it resemble.
yes, I did.
Sony Vaio VPCEE31FX
amd p340 dualcore
3 gig
laptop
sounds like someone humming. On startup it goes from low to high, on shutdown it is reversed.
Sony Vaio VPCEE31FX
amd p340 dualcore
3 gig
laptop
It must be the HDD reving up and down. If it really bothers you, replace the HDD with a SSD. That makes no sounds.
For me, all windows sounds are weird, that is why I always keep "no sounds" selected.
Windows 7 Ultimate x86/x64 dual bootIntel(R) Pentium(R) Dual CPU E2180 @ 2.00GHz2GB DDR2Intel 82945G Express Chipset Family v 8.15.10...
assembled locally.
ASUSTeK Computer INC. Model P5G-MX
2GB DDR2
Intel 82945G Express Chipset Family v 8.15.10.1930
Realtek High Definition Audio 2.65 v6..0.1.6449
LG Flatron W1943S
1360*760
Seagate SATA 250 GB, Seagate IDE 40 GB
beetel ATX
Intex
zebronics K06 non-multimedia
zebronics M05
3.1 Mbps reliance broadband+ (it crowls mostly)
I shut down; interestingly no sound accompanied shutdown, now.
I started up and hit F8 repeatedly, but did not get into SAFE mode. I've rarely used SAFE mode and don't know for sure that F8 should work on this Sony Vaio laptop.
The startup Sound played about the time I got to Desktop. Just checked and the Play Sound on Startup is NOT checked.
Sony Vaio VPCEE31FX
amd p340 dualcore
3 gig
laptop
Sony Vaio VPCEE31FX
amd p340 dualcore
3 gig
laptop
I'll assume you're joking...........??????????????
maybe not. It is a sound controllable with the speaker volume, which lasts about 2 seconds.
Sony Vaio VPCEE31FX
amd p340 dualcore
3 gig
laptop
If it is thru the speakers, then it is different. I was just thinking about the HDDs revving up and down because I hear that in my Dell box which is sitting on my desk next to me.
