Windows 7: does anyone actually have the Sound Stuttering fix?
26 Sep 2009   #11
Antman
Select software and drivers HP Pavilion Elite m9441uk Desktop PC - HP Customer Care (Canada - English)
You should also be able to use these files. I am particularly interested in BIOS and chipset updates. Then MAtrix.
I am saying, let's make sure all drivers are up to date.
Then let's look for CPU spikes and/or disk I/O spikes (like indexing or system retore snapshots).
26 Sep 2009   #12
Jebus23
windows 7
okay, everything is up tp date driver wise, I cannot update my bios though because im running windows 7 which the update does not support. I dont know if thats important. I ran the system diagnostics and it found nothing wriong at all. How do i look for spikes to see if thats causing the stuttering?
26 Sep 2009   #13
Antman
While it is stuttering, open Task Manager (rt clk taskbar).
Sort processes by CPU twice, bringing the highest numbers to the top. System idle is usually around 99%
27 Sep 2009   #14
Wayward
Windows 7 x64
I had a stuttering problem too with Windows 7 x64 RTM. Turns out it was Gigabyte's Easy Tune 6. I only use ET to control fan speeds, and it only causes stuttering when ET is open. Fortunately, ET can control fan speed without the ET console running.
27 Sep 2009   #15
Jag
Windows 7 x86
I use the RTM x86 for a laptop and have massively stuttering sound as well. Both using the internal sound card as well as an external usb sound card. Haven't found a solution yet.
27 Sep 2009   #16
Jebus23
windows 7
okay no spikes or anything like that, I also did a heat test and everything is running okay. I dual bootedfto to buid 6801 and the problem completely went away when using that os. unfortunately that particular build causes a different set of more annoying problems. I'm really at a loss with what to try next
28 Sep 2009   #17
Jag
Windows 7 x86
Tried the latency checker?
28 Sep 2009   #18
A320
Win 7 Ultimate x64
Quote   Quote: Originally Posted by pparks1 View Post
I had a massive audio stuttering problem...and in my case it was some gigabyte utility called Dynamic Energy Saver which I had installed that was causing the issue.
Energy managers, especially if you're overclocking, can often be the culprits here. I never really liked AMD's CoolNQuiet for example as even though it works I found it would choke with certain use such as my audio editors (Ableton Live) and even now when I play an MP3 with WMP it will stutter/static.
Check what your setting is here? If not 'high performance' try that and see if the problem changes.
28 Sep 2009   #19
Jebus23
windows 7
hey,
thnx jag
I used latency checker and sure enough i got the attached message. This at least is the first instance of a problem being acknowledged on my pc.
I will post back when i test to see if the realtek stuff in device manager, when disabled, fix the problem.
im also trying the high performance power option seperatly to see if that works.
28 Sep 2009   #20
Jebus23
windows 7
HELL YEAH.............
hey guys, okay look at the attachment.
The pic shows a latency checker along with my device manager, the real time latency checker once told me that there was something wrong with my devices
I tried disabaling realtek sound assuming that was the problem (I to have tried a million drivers) but the latency checker still said there was a problem, the spikes (in real time) used to correspond with sound stutter/buzzing/popping. Now i get no spikes because i disabled one of the 2 pcie express cards. Okay, i dont kno what pcie cards are, something about sonnecting motherboard to something, sounds important but so far my computer is working with no buzzin for the first time ever.
Might be wrong but at least this is some kind of lead....maybe...anyway, how come i have 2 drivers for pcie. Do you need 2. i wish I had another pc handy to see if 2 is common, just a guess but maybe having 2 causes a problem. GOOD LUCK. Im still glad mines working, i just hope there is no negative effects of the thing i disabled being disabled.
Stuttering sound and video
Hi I have an ongoing problem when listening to music or watching videos. Everything becomes fragmented and the sound and video will stutter. On two occasions when listening to music (via windows media player) the stuttering got so bad that the media player froze and i got the blue screen of...
Stuttering sound + Sound mixer "System Settings" flashing in and out
This is a weird issue I'm having. I did a restart and when I came back BF3 wasnt playing any sounds, which is weird because it was just working. I went to make sure it wasnt muted in the mixer, and I see the weirdest thing. The application "System Sound" is disapearing in and out very...
Sound and video stuttering.
I recently changed my system from a dual cored system and upgraded to the following spec AMD Phenom 9950 2.6ghz quad core Asrock Alive Xfire motherboard Corsair Extreme series SSD 32gb Windows 7 Pro ATI Radeon 5770 x2 in CrossfireX Sony Blu Ray reader NEC DVDRW Corsair Hydro series liquid...
Sound Stuttering on Audio CDs
Two drives, E: & F:. F works fine. E: stutters continuously when playing an audio CD. There is no problem with data, .MP3 etc, graphics/photos, only with audio CDs. Device Manager tells me the drivers are up-to-date. Rebooting doesn't help. Drive is a TSST CDDVDW SH-S223C ATA. Sound is...
Stuttering Sound
New user to windows 7! Everythign runs and works great minus the sound!!! It stutters and echoes very badly every so often. And being an avid player of Conan i use Vent. Vent does not even work. Any help provided is greatly appreciated!
