Windows 7: does anyone actually have the Sound Stuttering fix?
28 Sep 2009   #21
A320
Win 7 Ultimate x64
This means that your motherboard has 2 PCI-Express slots on it. These are the slots in which you install after market video cards. It is normal to have 1-4 depending on the type of motherboard you have. According to your specs, you have a 4870 video card, and that means it is plugged into one of these 2 slots. Your next challenge is to see if the problem is originating from the empty slot or the one with your video card.
Another thing you could check to troubleshoot is to see if your video card inside has a small black audio wire connected to it coming from somewhere off the motherboard or soundcard if you have one. If you do, and you are using the standard green/black/pink ports in the back for your speakers, then take this wire off your video card and see if this solves anything. Otherwise it could be the PCI-E slot in your motherboard itself or possibly the video card causing a disturbence in the PCI-E slot it's in. What make of PSU do you have? You seem to have enough power but the quality of PSU is important.
28 Sep 2009   #22
Antman
Just in case - make sure the video card is in the correct PCIe slot. Also, check BIOS for the correct setting for the slot, if any. Also, does the video card have a power connection - and if so, is it connected?
28 Sep 2009   #23
Jebus23
windows 7
My motherboard has only one pci-e slot. I remember because I had planned to get 2 4870 and run in crossfire. I installed it a few months back in the slot and yes it had a power connection. I would check to see if its still connected but the graphical capabilities of my machine at the moment would not be possible if it it was unconnected. Its strange that the problem is gone by disabling the pcie 802.11n wireless card. My pc still function the same. My gpu is working. I have sound without stuttering. Should I be worried?
28 Sep 2009   #24
Antman
If you do not use the wireless, and disabling it solves the problem, you are in good shape.
You will still have an unresolved problem in your system capabilities, but it will not affect you.
You may wish to reconsider your assumptions in your original post.
29 Sep 2009   #25
Jag
Windows 7 x86
The drivers are for network adapters that are using a PCI express slot, at least that's what windows thinks. From what i've read about DPC latency problems, is that they are caused by software problems. And often the driver for wireless network adapters are causing the problem.
So if you don't use it, disabling or removing it physically from your computer is a good option. If you do want to use it, search for an updated device driver.
21 Nov 2009   #26
SheepNutz
Windows 7 Professional 64 bit
Quote   Quote: Originally Posted by pparks1 View Post
I had a massive audio stuttering problem...and in my case it was some gigabyte utility called Dynamic Energy Saver which I had installed that was causing the issue.
I was having a stuttering sound issue in win7 x64, and having a gigabyte motherboard, I was hoping this was the problem. Well, I uninstalled the energy saver and the easy tune that someone else mentioned in this thread. Well, neither of those fixed the problem. I did finally pin it down to the program SpeedFan though. So, if anyone else is having an issue and has speedfan installed, exit the program and see if that fixes it.
23 Dec 2009   #27
StNick
Thank you A320! I changed my performance settings to "High Performance" as you suggested, and it seems to have resolved my issue!
23 Dec 2009   #28
A320
Win 7 Ultimate x64
Quote   Quote: Originally Posted by StNick View Post
Your welcome , it's nice when things get fixed!
28 Jan 2010   #29
surreyv8
windows 7 (64 bit)
Hello everyone, I'm new here. Please help. I'm having the same audio problems as some of you - stuttering on windows 7. It can be when using media player or any other sound and sequencing software. Since I compiled this equipment to produce music, it's a bit useless. I'm using an external Roland UA-25EX audio/midi interface as my soundcard. I had the same problem with Realtek and Creative soundcards.
Has anyone posted a remedy yet? Are Microsoft aware of this glitch? Also random mouse cursor - what's that all about? Just goes anywhere it wants!
19 Mar 2010   #30
Roycan
windows 7
Sound stuttering fix
I had the same problem. The bothering stuttering and then the computer switched off after one hour or more. I solved it this way: in device manager I disabled the driver that controls the slot PCI Express 2. I tried some other solutions, but unfortunately none of them seemed to work. Then I began to disable all the devices related to USB, sound, internet, and I got it. The program DPC Latency checker was a great help. I hope this can help somebody.
Stuttering sound and video
Hi I have an ongoing problem when listening to music or watching videos. Everything becomes fragmented and the sound and video will stutter. On two occasions when listening to music (via windows media player) the stuttering got so bad that the media player froze and i got the blue screen of...
Stuttering sound + Sound mixer "System Settings" flashing in and out
This is a weird issue I'm having. I did a restart and when I came back BF3 wasnt playing any sounds, which is weird because it was just working. I went to make sure it wasnt muted in the mixer, and I see the weirdest thing. The application "System Sound" is disapearing in and out very...
Sound and video stuttering.
I recently changed my system from a dual cored system and upgraded to the following spec AMD Phenom 9950 2.6ghz quad core Asrock Alive Xfire motherboard Corsair Extreme series SSD 32gb Windows 7 Pro ATI Radeon 5770 x2 in CrossfireX Sony Blu Ray reader NEC DVDRW Corsair Hydro series liquid...
Sound Stuttering on Audio CDs
Two drives, E: & F:. F works fine. E: stutters continuously when playing an audio CD. There is no problem with data, .MP3 etc, graphics/photos, only with audio CDs. Device Manager tells me the drivers are up-to-date. Rebooting doesn't help. Drive is a TSST CDDVDW SH-S223C ATA. Sound is...
Stuttering Sound
New user to windows 7! Everythign runs and works great minus the sound!!! It stutters and echoes very badly every so often. And being an avid player of Conan i use Vent. Vent does not even work. Any help provided is greatly appreciated!
