Microphone not Working ?
  1. Posts : 26
    Microsoft Windows 7 Starter 32-bit 7601 Multiprocessor Free Service Pack 1
    I buyed several headset with microphones but its still not working.
    I have put the headset wires correct but still not working .
    I have a non-branded headset with mic but I tested it on other computers and it works but on my pc its not working .
    Any Help please ?
  2. Posts : 81
    windows 7 ultimate x32
    see speaker icon in taskbar ?
    right click the icon
    you see " playback device and recording device ?
    click recording
    click microphone icon
    and then click propeties
    go to level Tab,
    you see that sound level,just make 100%,your honey will hear your sounds
    or if you can see microphone icon..
    don't panic,it must be disabled..
    go to recording tab,
    right click,
    show all disable device...
    and then you finish
  3. Posts : 26
    click recording
    go to level Tab,
    right click,
    and then you finish
    well thanks for answering I will try that later
